Auto Trans help
erawtik
Sep 22, 2005
Des Moines, Iowa
The car is a 94 GS 2.0. When I bought the car it wouldnt move in any gear. So I went and got a new tranny and installed it with a new torque converter. And when I mean new I mean from the junk yard. After installing this tranny it is the same thing. I did take the torque converter out of the new tranny when I got it. Now im wondering if I may of damaged the front pump? Iv heard that it is easy to damage the pump. Or is there something else for me to check? Tranny fluid stays the same level never gets warm. And if it is the pump where to look to find one the local stores dont have them.
This may sound stupid but did you physically check to make sure the transmission shifter is moving when you move it in the car. Could just be a broken cable. I have had experience with N/T transmission's and never had any problem's with the pump going out before.
Yes the shifter moves and it makes the clicky noises in gears with engine off but key on.
Did you check your nuetral safety switch to make sure it isn't overriding the silioid in the transmission and not allowing it to go into gear.
