1g Auto trans help needed
2wdlaser
52
Mar 2, 2011
Germansville, Pennsylvania
Ok So I've goggled, I have looked every where. I can't find any info on the problem I'm having. So I did an engine swap in my 91 Plymouth laser rs turbo. Its an auto. Tranny wise when I took everything out was fine. Ok So i replaced the engine. Fires up great. Go to put it in drive and nothing happens. Turned overdrive off did nothing. I can hear what i think is a solonod clicking. Only clicks when I put it in R,D.123. not in N OR P. I found the plug cause when i unplug it, the clicking stops. My question is how do i replace it. And or what is it. or could it be something totally different. If ## an auto trans guru for a dsm. Hit me up cause we need to talk.
It went on with ease. I mean the tranny was heavy but no problems once we had it lined up.
When I unplug it it does nothing.
So I pulled one off the tranny cooler lines. Off and nothing came out.
Was the car running when you pulled the line off. I remember I was having a similar problem with my car when I first put the transmission in but it turned out there was air in the lines. I started the car took the return line off let it run until oil flowed out and quickly put the line on. Shifted just fine after that.
Ya the car was running. I only let run for like a min. Should I let it it run longer
Ok so yesterday, i took the trans back down. Put the trans back up. checked everything. Still clicking.
