bryzenga
- 158
- 6
- Jan 8, 2009
Holland,
Michigan
Having a problem with my passenger side auto seatbelt. When the ignition is turned on, the slider travels from the disengaged(open) position as it should, but when it reaches the engaged position(closed), it does not stop and stay as it should. All it does is slide up and down continuously as if one sensor is telling the car that the door is open and another sensor is saying that the door is closed. It started doing this last fall, so I just unplugged it because I couldn't figure out what to replace. I know that there is a small black box inside the door itself, but from other threads I have read were about the seatbelt not working at all, and their issues were attributed to that small black box. Nothing changes when the door is closed or open. When the ignition is turned off, it slides down the track to the disengaged position as it should. Wondering if anyone else has had this problem and can tell me what exactly is going on before I just start replacing parts.
