madscientist323
- 0
- Nov 14, 2004
philadelphia,
Pennsylvania
i saw one on ebay what benefits does this have
99gst_racer said:Sometimes it can help supress boost creep a little bit. It will not fully fix it though. Many people say it also allows for quicker spool up. It is also ver, very loud at WOT. Sounds very unique. Don't buy it expecting to add 20 HP or gain 2 tenths.....
Yeah, I have yet to see a DSM consistently knock off a half second from their 1/4 ET's from only O2 dumping....... But I'm glad it worked on you 3Kgt.Shadowfax said:my experience O2 dumps took off .5 and gained 4mph - course that was with two on stock 3/S turbos in a 4000lb AWD 3000GT VR4 - at wastegate boost too
We are comparing a O2 dump housing to a factory OEM cast O2 housing.....David15151 said:yeah but are we comparing 02 dump vs stock piece or 02 dump vs aftermarket eliminator.. you see what im saying?
99gst_racer said:Yeah, I have yet to see a DSM consistently knock off a half second from their 1/4 ET's from only O2 dumping....... But I'm glad it worked on you 3Kgt.
I figure if you've got a 14B and are pushing 17psi then you should see some sort of gains from an O2 with a 2.5" exhaust- on 3" exhaust, I'm hoping you would (find out soon
)Shadowfax said:my experience O2 dumps took off .5 and gained 4mph - course that was with two on stock 3/S turbos in a 4000lb AWD 3000GT VR4 - at wastegate boost too
The O2 dump should pick up some HP - specially if your exhaust is only 2.5"
Consider it- you've got enough air running thru the turbo to maintain power- but you're bypassing the turbine once the wastegate opens - so if you are just running 15psi on even a 14B, the wastegate will open and you'll be dumping that air into the exhaust after the turbo- any time you decrease the pressure on the outlet of the turbine, you're going to get more efficient flow thru it- thus by taking the wastegate air out of the equation- you'll find HP.
If you are putting an O2 dump on a T25 run at 17psi- your wastegate won't open, and you'll gain NOTHING.
If you have 3" exhaust, and a smaller turbo, you might not get much gain- the exhaust was pretty unrestricted anyway.
Long and short- if running 2.5" exhaust- expect. If running 3" with small turbo- don't.
.theres no extra tubes pipes or anything?just unbolt stock and put the new one in its place does the o2 sensor still thread in?Shadowfax said:if you take the stock one off, the new one goes on exactly the same.
madscientist323 said:theres no extra tubes pipes or anything?just unbolt stock and put the new one in its place does the o2 sensor still thread in?
ikickuintheball said:).
BTW, you're retarded if you think the wg doesn't open if you run 17psi with an 8psi (or so) wastegate..
Shadowfax said:typically I'm used to the 3/S world- I'm rather a newbie in the DSM world (though I've been paying attention) - in the 3/S world- the 9b is like the T25- it can't keep up with demands. hence running it at 15psi yields a brief spike, then ever decreasing boost- and the dumps confirmed that the wastegates never opened
If the T25 acts differently, then my apologies
When I ran the dump on my t25, I could run 20psi (brief spike going down to 15psi) and I would hear the dump the whole way.talon96tsi said:would running an o2 dump with a 14b at 14psi be worth it, along with my 3" br turbo back...im trying to eliminate my boost creep, which is to say the least incrdeibly annoying. Along with porting the *#$% out of my turbine housing im trying to find way to make it go bye bye
When you were creeping, what was your boost set at and what were you creeping to?Coup D E'Tat said:A dump elminated creep on my 14b/3" exhaust without porting, boost at 12-ish PSI
