At what psi does the MHI16g become a hairdryer
Ill be using my stock sidemont with devils own water injection,750ccFIC's,and a dual image stage 3 keydiver
edit: Big 16g
I dont believe that at all. Im sorry , but i know i can run more than that:thumb:
All stock at 32psi. Thats wild
I dont think that he saw your water injection. I would say 22 or so, just because your air is going to be so hot from the sidemount that your water is not going to be enough. IMO
With my big 16G and just a stock sidemount I was limited to about 15psi as soon as the temps hit the mid 70's heat soak and knock like crazy. Unless someone else has done exactly what you want to do I think you are going to have to find out for yourself exactly what the water/meth injection can do with that.
I did see the inj. and like was mentioned above, as soon as the SMIC heat soaks the car will knock.
It's not all about the boost, people. Come on now.
Do your own conversions. I'm lazy. :D
