At what pressure will injectors still atomize fuel well?
linksys42
412
30
Jan 8, 2003
Union, Missouri
Taboo said:
Reset the ECU to start with (in order to get rid of your messed-up trims and load fresh timing maps), reset the ISC servo, pressure-test the intake, make sure the TB plate is all the way closed at idle and all the way open at WOT, adjust the TPS, and set the BISS 2.5 turns out. Set the S-AFC to 0 or slightly bellow across the entire board and use NOTHING but the AFPR to get within the ECU adjustment range (= do not touch the S-AFC AT ALL. Just pretend it's not even there). The trims do NOT have to be exactly 0%. Adjust the idle with the BISS. All there's to it. Use just and only the AFPR to establish the rough fuel curve and the S-AFC to supply the ECU with the correct airflow. Because of the hacked MAS (or different turbo response - in case of someone with an aftermarket turbo) the "correct" airflow the ECU expects to see is not going to form a straight line on the S-AFC and does not really mater where the curve on the S-AFC is located as long as the ECU is supplied with the "correct" airflow values. One can and will use the S-AFC to fine tune the fuel curve (once it's established with the AFPR), but there's going to be never ending compromise between manipulating the actual AFR and affecting the timing in the process by feeding the ECU by "incorrect" airflow values. There are just two simple things you have to do: 1) establish the correct airflow values with the S-AFC and 2) establish the fuel curve with the A-FPR while staying within the adjustment range of the ECU. If you do that, your car is roughly tuned and you can continue fine-tuning it with the AFPR and the S-AFC in order to improve the throttle response, get rid of knock caused by incorrect AFR or timing at particular RPM range and airflow, etc. Don't be obssessed with 0% trims and 0 knock. Lean the bi*** out (with the AFPR) as much as you can at WOT 'til she starts dropping timing, then go a notch back up with the fuel pressure. However, you can do that only after the LTFT is established.
I was wondering if this approach to tuning would be fine with 650’s? Because to get the O2’s to cycle I would think you would be pretty low in the fuel pressure with the AFC zeroed out with the 650’s. What I am wondering is how low of fuel pressure is to low? At what pressure will injectors still atomize fuel well? Because at 30 psi of base fuel pressure you should be able to flow the 650’s at about 448cc. And at 37psi of base pressure I should be able to run the injectors at 552cc. Correct me if Im wrong. Just wondering how low of fuel pressure is safe when tuning with an AFPR. Thanks
What's the point? You're going to install 650cc injectors only to turn the fuel pressure down so they flow 450cc's. The ecu won't know the difference, but you won't be gaining any more fuel flow capacity.
The idea is to lower it down to get a base tune where the ecu is at its stock timing and fuel maps. Running stock boost to get a good base line then bump the boost up a psi or two than bump the fuel pressure and make minor adjustments with the safc to dial in the tune and keep repeating the process till you reach the boost pressure that you are shooting for. That way you are at the lowest map for the timing and fuel so you don't have to take so much out with just the afc. I have been having problem with knock and I am guessing it is because of the high timing from the afc that's why I am trying to get it closer to the stock maps. The thing is that I cannot lean the car out? With the 650's in and the fuel pressure at 43.5 I am only able to pull out –22 to –23 without it knocking on my high throttle settings. And that is with my wide band pegged at below 10.0:1 that's all my AEM uego will read on the gage. I have tried to lean it out more but the knock keeps going up and up. Any suggestions would be great. Also what could be the draw back to running the fuel pressure at a lower number, I know it wont atomize as well as if it were at 43.5psi the pressure rating that the injector was designed to run at. But will it hurt anything?
After a certain point, it will start to run into problems (esp. early into the pull, assuming you go crazy low). No one can say for sure when the atomization becomes an issue unless they experimented and found out.
In essence, you're running into the limitations of a SAFC setup is all. Read through this thread if you don't believe me-- http://www.dsmtuners.com/forums/log-file-advice/275390-new-log-pte-54-trim-3227e-join-tuning.html
The gist of it is that you'll have to somehow get enough airflow to keep yourself in the upper timing map, while at the same time trying not to pull too much airflow which would knock you back down to a lower timing map.
Ya, I understand the timing tables from the airflow that the ecu sees. But what I don’t understand is why when I turn the boost up to 20psi or 1.7 g/rev that the ecu sees after the afc corrects it, I am on the timing table of a peak of 19-22 degrees. But I can only lean the afc to about –22 to –23 when others have been able to lean it out to at least –31 or farther?
Perhaps they have higher airflow than what you're getting. If they're pulling more airflow than you and staying on the same load table (or an even higher one), then they've got to be moving more air than you.
Hate to say it, but simply every car and motor setup will require slightly to marginally different maps/tuning even with all the same parts. Can't you just dial down teh LOW throttle areas at idle and then have the HI settings for WOT set safely still? I only ran 550's on my AFC, then i stepped up to stand alone fuel management because of teh ill effects of pulling too much air from what teh ECU could see. ( i did love the S-AFC though, it was fun for a year or 2 )
ya i wish that was it but they were runing only 17-19 psi and the exact same set up but pulling -30's out of the afc? i dont get it. the only explanation i can think of is like turboglen is saying that every set up is different. but i really dont think that it would be that much of a difference? I dont get it? Was also wondering what you think crazy low fuel pressure would be?
Your right about all cars tunes being different, but I thought that I would be remotely close to being able to pull out enough fuel to get close to 11.1:1 a/f ratio at least? Thanks for all the help opinions guys.
The difference in airflow could be due to having a setup with greater VE, and thus more airflow at the same boost. OR, they could have the same setup as you, but not care about running high timing on pump gas. If you can pull -30% air and get dropped to a lower load timing map, yet still run without getting knock, then there's not much to worry about.
If you can stay above at least 1.8 g/rev, then your ECU would shoot for 19 degrees peak timing. That's *somewhat* doable (I say somewhat because a lot of people go for high boost low timing), although you may have to look into adding some E85 or some sort of injection to do it.
The lowest fuel pressure that I've seen anyone run on a regular basis is 32 psi. The car also has 1600cc injectors, runs on straight E85, and has 280* cams--not exactly a street car. He does drive the car around town and comments on poor street manners, but that's due to any number of things.
Ya now that I am having problems with this I wish I would have went with the ball bearing 5031re. But hindsight is 20/20. I was going to order engine runup water/meth kit soon here. Looks like really soon. I have done some reading on e85 and I can get it here im my town and its really cheap! I can also get 103 octane at the pump here also but it’s like 5.00 dollars a gallon! What exactly do I need to convert too to run e85? Or can I just run it with no ill effects? I would think that ethanol would be corrosive to certain fuel supply parts? And can the e85 be mixed with 93 to a mixture of like 2 to 1? How are people mixing it or what ratio do people run to get good results? Thanks again for all the help!
Lots of people have been running E85 without any issues on the stock lines/rail/etc. The only thing that I would really worry about would be the fuel pumps, as that would probably be the first to fail. There's a list somewhere of E85 compatible fuel pumps, but I do know that the common Walbro pumps as well as the Supra pump are all E85 compatible.
People do mix E85 with pump gas, you just have to tune for it. The exact ratio is up to you, as there isn't really a "recommended" ratio as far as I know.
The real issue with running big power on E85 is that it puts huge demands on your fuel system, especially your fuel pump(s). Colloquial reports say that you need 30% more fuel when running E85 than with pump gas.
I've got some preliminary estimations, but with E85 being really out of the way for me, I haven't had a chance to really test it out. I'll send it to you via a PM though.
Try searching threads on Colorado DSM Club Forums - Powered by vBulletin and Rocky Mountain DSM Forums - Rocky Mountain DSM . There are a number of guys here in Colorado running straight and/or mixed E85. There's a thread on the first site where members list their setups. Here ya go: Post your E85 setup - Colorado DSM Club Forums
30% more fuel, a 255 Wally w/AFPR, and at least 850cc injectors are the bottom end of what's required by most people running it around here. Oh, and Link or some other standalone for fuel management (not an AFC...).
Edit - I've played around with mixing it with pump 91, but my IDC's are already borderline with the amount of boost I'm running, so I typically throw fuel trim CEL's when I mix it in, even with an AFC. And I'm not going to give up any psi :)
I am running a walbro 190L with the 650’s afpr and big 16g so with a 30% more demand I would only be able to run safely at about 15-16 psi correct? If so, if I watered down the e85 with 93 say a 50/50 mix I should be able lessen the demand of 30% more fuel to around 15% so I can at least run 18psi and be able to lean it out to around 11.0:1 to 12.0:1. And when tuning i should just aim for that a/f ratio with 0-3 counts across the band. If you have any other recommendations let me know I really appreciate it.
I am running a walbro 190L with the 650's afpr and big 16g so with a 30% more demand I would only be able to run safely at about 15-16 psi correct?
I would say that is about right, as I figured 14-15psi on my car (rewired190/550's/E316g).
That's too much for me LOL I only have a shallow knowledge of how these things interact...I don't want to tell you the wrong thing!
Go check out those forums I linked to, and read up a bit, as there's been a lot of discussion regarding E85 on those boards this year. And join and ask questions, especially co.dsm.org...lots of friendly knowledge there. There are also a couple of threads here on Tuners about E85 that are fairly informative.
I shot you a PM that should answer those questions, although it's all based on some theory. In essence, fuel flow demands increase proportionately to airflow increase. It's not so much how much boost you can run, but how much air you're trying to flow.
Lower airflow numbers will allow you to run more E85 with the same injector flow requirements--using the numbers from the PM I sent you: given 600 cc/min of usable flow (92% IDC), with 45 lbs/min of air you'd only be able to run 1 or 2 gallons of E85, whereas with 40 lbs/min you'd be able to run 10 gallons.
Edit: I thought you had a 54 trim for some unknown reason. In this case, you should be fine as a typical 16g setup on a relatively stock motor averages around 35 lbs/min.
Can you post a datalog, along with the boost setting, fuel pressure, any wideband data you have, and safc settings for that particular datalog.
I don't get why when I post the html code it puts this long space in? Any way you need to scroll down to see the log. Its at 19-20 psi, fuel 43.5 psi, flowing 30.6 lbs/min, 2.1 g/rev. Hi settings on this log are -22 all the way across didn't fine tune it just plugged them all in quick. Wide band is off the chart pig rich all the way thru the run. the 0-5 signal wire off the wide band is spliced into the 2nd o2 sensor pinout on the ecu.These are 650's. Thanks
Code:
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=894 style='border-collapse:
 collapse;table-layout:fixed;width:672pt'>
 <col width=80 style='mso-width-source:userset;mso-width-alt:2925;width:60pt'>
 <col width=98 style='mso-width-source:userset;mso-width-alt:3584;width:74pt'>
 <col width=92 style='mso-width-source:userset;mso-width-alt:3364;width:69pt'>
 <col width=123 style='mso-width-source:userset;mso-width-alt:4498;width:92pt'>
 <col width=94 style='mso-width-source:userset;mso-width-alt:3437;width:71pt'>
 <col width=108 style='mso-width-source:userset;mso-width-alt:3949;width:81pt'>
 <col width=107 style='mso-width-source:userset;mso-width-alt:3913;width:80pt'>
 <col width=114 style='mso-width-source:userset;mso-width-alt:4169;width:86pt'>
 <col width=78 style='mso-width-source:userset;mso-width-alt:2852;width:59pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 width=80 style='height:12.75pt;width:60pt'>TPS</td>
  <td width=98 style='width:74pt'>RPM</td>
  <td width=92 style='width:69pt'>TimingAdv</td>
  <td width=123 style='width:92pt'>AirFlow</td>
  <td width=94 style='width:71pt'>O2Sensor</td>
  <td width=108 style='width:81pt'>O2Sensor2</td>
  <td width=107 style='width:80pt'>AirTemp</td>
  <td width=114 style='width:86pt'>InjDutyCycle</td>
  <td width=78 style='width:59pt'>KnockSum</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="22.745098039215701">22.745098</td>
  <td align=right x:num>2656.25</td>
  <td align=right x:num>33</td>
  <td align=right x:num>100.64</td>
  <td align=right x:num="9.7500000000000003E-2">0.0975</td>
  <td align=right x:num="2.4569999999999999">2.457</td>
  <td align=right x:num="79.205919999999907">79.20592</td>
  <td align=right x:num="3.9666666666666699">3.966666667</td>
  <td align=right x:num>0</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="33.725490196078397">33.7254902</td>
  <td align=right x:num>31</td>
  <td align=right x:num>163.54</td>
  <td align=right x:num="2.6324999999999998">2.6325</td>
  <td align=right x:num>6.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="63.529411764705898">63.5294118</td>
  <td align=right x:num>2750</td>
  <td align=right x:num>27</td>
  <td align=right x:num>276.76</td>
  <td align=right x:num="0.87749999999999995">0.8775</td>
  <td align=right x:num="2.3595000000000002">2.3595</td>
  <td align=right x:num>10.56</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>80</td>
  <td align=right x:num>2687.5</td>
  <td align=right x:num="0.76049999999999995">0.7605</td>
  <td align=right x:num="2.2425000000000002">2.2425</td>
  <td align=right x:num="78.410550004000399">78.41055</td>
  <td align=right x:num>10.32</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>100</td>
  <td align=right x:num>28</td>
  <td align=right x:num>283.05</td>
  <td align=right x:num="1.7355">1.7355</td>
 </tr>
  <td align=right x:num>2781.25</td>
  <td align=right x:num>295.63</td>
  <td align=right x:num="5.8500000000000003E-2">0.0585</td>
  <td align=right x:num="2.8079999999999998">2.808</td>
  <td align=right x:num="11.2733333333333">11.27333333</td>
 </tr>
  <td align=right x:num>2812.5</td>
  <td align=right x:num>314.5</td>
  <td align=right x:num="0.11700000000000001">0.117</td>
  <td align=right x:num>12.6</td>
 </tr>
  <td align=right x:num>2843.75</td>
  <td align=right x:num>26</td>
  <td align=right x:num>327.08</td>
  <td align=right x:num="00.78">0.78</td>
  <td align=right x:num="2.7885">2.7885</td>
  <td align=right x:num="13.3466666666667">13.34666667</td>
 </tr>
  <td align=right x:num>2875</td>
  <td align=right x:num>345.95</td>
  <td align=right x:num="0.83850000000000002">0.8385</td>
  <td align=right x:num="2.2814999999999999">2.2815</td>
  <td align=right x:num="14.106666666666699">14.10666667</td>
 </tr>
  <td align=right x:num>2906.25</td>
  <td align=right x:num>358.53</td>
  <td align=right x:num="0.85799999999999998">0.858</td>
  <td align=right x:num="1.9305000000000001">1.9305</td>
  <td align=right x:num>14.88</td>
 </tr>
  <td align=right x:num>2937.5</td>
  <td align=right x:num>24</td>
  <td align=right x:num>377.4</td>
  <td align=right x:num="1.8525">1.8525</td>
  <td align=right x:num="15.6666666666667">15.66666667</td>
 </tr>
  <td align=right x:num>2968.75</td>
  <td align=right x:num>23</td>
  <td align=right x:num>396.27</td>
  <td align=right x:num="1.794">1.794</td>
  <td align=right x:num>17.1</td>
 </tr>
  <td align=right x:num>3031.25</td>
  <td align=right x:num>22</td>
  <td align=right x:num>421.43</td>
  <td align=right x:num="1.6964999999999999">1.6965</td>
  <td align=right x:num="77.621187375999696">77.62118738</td>
  <td align=right x:num="18.106666666666701">18.10666667</td>
 </tr>
  <td align=right x:num>3062.5</td>
  <td align=right x:num>20</td>
  <td align=right x:num>446.59</td>
  <td align=right x:num="1.6379999999999999">1.638</td>
  <td align=right x:num>19.6</td>
 </tr>
  <td align=right x:num>3093.75</td>
  <td align=right x:num>19</td>
  <td align=right x:num>471.75</td>
  <td align=right x:num="1.599">1.599</td>
  <td align=right x:num>20.46</td>
 </tr>
  <td align=right x:num>3156.25</td>
  <td align=right x:num>17</td>
  <td align=right x:num>509.49</td>
  <td align=right x:num="1.5405">1.5405</td>
  <td align=right x:num="22.893333333333299">22.89333333</td>
 </tr>
  <td align=right x:num>3187.5</td>
  <td align=right x:num>15</td>
  <td align=right x:num>540.94</td>
  <td align=right x:num="1.4039999999999999">1.404</td>
  <td align=right x:num>24.48</td>
 </tr>
  <td align=right x:num>3250</td>
  <td align=right x:num>14</td>
  <td align=right x:num>584.97</td>
  <td align=right x:num="1.3845000000000001">1.3845</td>
  <td align=right x:num="27.733333333333299">27.73333333</td>
 </tr>
  <td align=right x:num>3281.25</td>
  <td align=right x:num>12</td>
  <td align=right x:num>629</td>
  <td align=right x:num="0.89700000000000002">0.897</td>
  <td align=right x:num>1.17</td>
  <td align=right x:num>30.8</td>
 </tr>
  <td align=right x:num>3343.75</td>
  <td align=right x:num>11</td>
  <td align=right x:num>673.03</td>
  <td align=right x:num="0.97499999999999998">0.975</td>
  <td align=right x:num>34.24</td>
 </tr>
  <td align=right x:num>3406.25</td>
  <td align=right x:num>10</td>
  <td align=right x:num>735.93</td>
  <td align=right x:num="0.91649999999999998">0.9165</td>
  <td align=right x:num="0.95550000000000002">0.9555</td>
  <td align=right x:num="38.5133333333333">38.51333333</td>
 </tr>
  <td align=right x:num>3437.5</td>
  <td align=right x:num>9</td>
  <td align=right x:num>798.83</td>
  <td align=right x:num="0.54600000000000004">0.546</td>
  <td align=right x:num="42.533333333333303">42.53333333</td>
 </tr>
  <td align=right x:num>3531.25</td>
  <td align=right x:num>8</td>
  <td align=right x:num>874.31</td>
  <td align=right x:num="0.312">0.312</td>
  <td align=right x:num="46.706666666666699">46.70666667</td>
 </tr>
  <td align=right x:num>3593.75</td>
  <td align=right x:num>899.47</td>
  <td align=right x:num="49.066666666666698">49.06666667</td>
 </tr>
  <td align=right x:num>3656.25</td>
  <td align=right x:num="0.93600000000000005">0.936</td>
  <td align=right x:num>49.14</td>
 </tr>
  <td align=right x:num>3718.75</td>
  <td align=right x:num="49.186666666666703">49.18666667</td>
 </tr>
  <td align=right x:num>3812.5</td>
  <td align=right x:num>918.34</td>
  <td align=right x:num="50.426666666666698">50.42666667</td>
 </tr>
  <td align=right x:num>3875</td>
  <td align=right x:num>937.21</td>
  <td align=right x:num>52.08</td>
 </tr>
  <td align=right x:num>3937.5</td>
  <td align=right x:num>956.08</td>
  <td align=right x:num>52.92</td>
 </tr>
  <td align=right x:num>3968.75</td>
  <td align=right x:num>968.66</td>
  <td align=right x:num>53.34</td>
 </tr>
  <td align=right x:num>4062.5</td>
  <td align=right x:num>987.53</td>
  <td align=right x:num="55.466666666666697">55.46666667</td>
 </tr>
  <td align=right x:num>4125</td>
  <td align=right x:num>1000.11</td>
  <td align=right x:num>56.32</td>
 </tr>
  <td align=right x:num>4187.5</td>
  <td align=right x:num>1006.4</td>
  <td align=right x:num="7.8E-2">0.078</td>
  <td align=right x:num="57.173333333333296">57.17333333</td>
 </tr>
  <td align=right x:num>4218.75</td>
  <td align=right x:num>1025.27</td>
  <td align=right x:num>57.6</td>
 </tr>
  <td align=right x:num>4281.25</td>
  <td align=right x:num>1050.43</td>
  <td align=right x:num="59.366666666666703">59.36666667</td>
 </tr>
  <td align=right x:num>4343.75</td>
  <td align=right x:num>1075.59</td>
  <td align=right x:num>61.16</td>
 </tr>
  <td align=right x:num>4406.25</td>
  <td align=right x:num>1088.17</td>
  <td align=right x:num>62.04</td>
 </tr>
  <td align=right x:num>4468.75</td>
  <td align=right x:num>1100.75</td>
  <td align=right x:num="63.873333333333299">63.87333333</td>
 </tr>
  <td align=right x:num>4562.5</td>
  <td align=right x:num>1132.2</td>
  <td align=right x:num="66.186666666666696">66.18666667</td>
 </tr>
  <td align=right x:num>1138.49</td>
 </tr>
  <td align=right x:num>4625</td>
  <td align=right x:num>1151.07</td>
  <td align=right x:num="67.093333333333305">67.09333333</td>
 </tr>
  <td align=right x:num>4718.75</td>
  <td align=right x:num>1157.36</td>
  <td align=right x:num="68.453333333333305">68.45333333</td>
 </tr>
  <td align=right x:num>4750</td>
  <td align=right x:num>1176.23</td>
  <td align=right x:num="68.906666666666695">68.90666667</td>
 </tr>
  <td align=right x:num>4812.5</td>
  <td align=right x:num>1169.94</td>
  <td align=right x:num="68.786666666666704">68.78666667</td>
 </tr>
  <td align=right x:num>4875</td>
  <td align=right x:num>1182.52</td>
  <td align=right x:num>69.68</td>
 </tr>
  <td align=right x:num>4937.5</td>
  <td align=right x:num>1201.39</td>
  <td align=right x:num="70.573333333333295">70.57333333</td>
 </tr>
  <td align=right x:num>4968.75</td>
  <td align=right x:num>1207.68</td>
  <td align=right x:num>71.02</td>
 </tr>
  <td align=right x:num>5000</td>
  <td align=right x:num>1220.26</td>
  <td align=right x:num="71.466666666666697">71.46666667</td>
 </tr>
  <td align=right x:num>5093.75</td>
  <td align=right x:num>13</td>
  <td align=right x:num>1245.42</td>
  <td align=right x:num="72.8066666666667">72.80666667</td>
 </tr>
  <td align=right x:num>5156.25</td>
  <td align=right x:num>1251.71</td>
  <td align=right x:num>73.7</td>
 </tr>
  <td align=right x:num>1264.29</td>
 </tr>
  <td align=right x:num>5250</td>
  <td align=right x:num>1270.58</td>
  <td align=right x:num>75.04</td>
 </tr>
  <td align=right x:num>5281.25</td>
  <td align=right x:num>1283.16</td>
  <td align=right x:num="75.486666666666693">75.48666667</td>
 </tr>
  <td align=right x:num>5343.75</td>
  <td align=right x:num>75.24</td>
 </tr>
  <td align=right x:num>5375</td>
  <td align=right x:num>1302.03</td>
  <td align=right x:num>75.68</td>
 </tr>
  <td align=right x:num>5437.5</td>
  <td align=right x:num>1308.32</td>
  <td align=right x:num>76.56</td>
  <td align=right x:num>1</td>
 </tr>
  <td align=right x:num>5500</td>
  <td align=right x:num>1320.9</td>
  <td align=right x:num>77.44</td>
 </tr>
  <td align=right x:num>5562.5</td>
  <td align=right x:num>1327.19</td>
  <td align=right x:num="77.133333333333297">77.13333333</td>
 </tr>
  <td align=right x:num>5593.75</td>
  <td align=right x:num>1339.77</td>
  <td align=right x:num="77.566666666666706">77.56666667</td>
 </tr>
  <td align=right x:num>5656.25</td>
  <td align=right x:num>1333.48</td>
  <td align=right x:num="76.837683178000205">76.83768318</td>
  <td align=right x:num="77.226666666666702">77.22666667</td>
 </tr>
  <td align=right x:num>5687.5</td>
  <td align=right x:num>18</td>
  <td align=right x:num="77.653333333333293">77.65333333</td>
 </tr>
  <td align=right x:num>5718.75</td>
  <td align=right x:num>1346.06</td>
  <td align=right x:num>78.08</td>
 </tr>
  <td align=right x:num>5781.25</td>
  <td align=right x:num>1352.35</td>
  <td align=right x:num="78.933333333333294">78.93333333</td>
 </tr>
  <td align=right x:num>5843.75</td>
  <td align=right x:num>78.54</td>
 </tr>
  <td align=right x:num>5875</td>
  <td align=right x:num="77.706666666666706">77.70666667</td>
 </tr>
  <td align=right x:num>5906.25</td>
  <td align=right x:num>1358.64</td>
  <td align=right x:num>79.38</td>
 </tr>
  <td align=right x:num>5968.75</td>
  <td align=right x:num="78.946666666666701">78.94666667</td>
 </tr>
  <td align=right x:num>6000</td>
  <td align=right x:num>1364.93</td>
  <td align=right x:num>79.36</td>
 </tr>
  <td align=right x:num>6062.5</td>
  <td align=right x:num="78.893333333333302">78.89333333</td>
 </tr>
  <td align=right x:num>6093.75</td>
  <td align=right x:num>1371.22</td>
  <td align=right x:num>79.3</td>
 </tr>
  <td align=right x:num>6156.25</td>
  <td align=right x:num="80.113333333333301">80.11333333</td>
 </tr>
  <td align=right x:num>6187.5</td>
  <td align=right x:num>79.2</td>
 </tr>
  <td align=right x:num>6250</td>
  <td align=right x:num>1383.8</td>
  <td align=right x:num>80</td>
 </tr>
  <td align=right x:num>6312.5</td>
  <td align=right x:num>21</td>
  <td align=right x:num>80.8</td>
 </tr>
  <td align=right x:num>1377.51</td>
 </tr>
  <td align=right x:num>6375</td>
  <td align=right x:num>80.24</td>
 </tr>
  <td align=right x:num>6406.25</td>
  <td align=right x:num>1396.38</td>
  <td align=right x:num>82</td>
 </tr>
  <td align=right x:num>6437.5</td>
  <td align=right x:num="81.026666666666699">81.02666667</td>
 </tr>
  <td align=right x:num>6500</td>
  <td align=right x:num>1402.67</td>
  <td align=right x:num="81.813333333333304">81.81333333</td>
 </tr>
  <td align=right x:num="76.059857920000397">76.05985792</td>
 </tr>
  <td align=right x:num>6531.25</td>
  <td align=right x:num>1415.25</td>
  <td align=right x:num="82.206666666666706">82.20666667</td>
 </tr>
  <td align=right x:num>6562.5</td>
  <td align=right x:num>81.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="44.313725490196099">44.3137255</td>
  <td align=right x:num>6593.75</td>
  <td align=right x:num>748.51</td>
  <td align=right x:num="0.64349999999999996">0.6435</td>
  <td align=right x:num="0.13650000000000001">0.1365</td>
  <td align=right x:num="28.133333333333301">28.13333333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="14.117647058823501">14.1176471</td>
  <td align=right x:num>38</td>
  <td align=right x:num>232.73</td>
  <td align=right x:num="0.624">0.624</td>
  <td align=right x:num>11.82</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=80 style='width:60pt'></td>
  <td width=98 style='width:74pt'></td>
  <td width=92 style='width:69pt'></td>
  <td width=123 style='width:92pt'></td>
  <td width=94 style='width:71pt'></td>
  <td width=108 style='width:81pt'></td>
  <td width=107 style='width:80pt'></td>
  <td width=114 style='width:86pt'></td>
  <td width=78 style='width:59pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
You need to scroll down to see the log also. Its at 19-20 psi, fuel 43.5 psi, flowing 30.6 lbs/min, 2.1 g/rev. Hi settings on this log are -23 all the way across. if i keep taking out air the knock and timing pull just gets worse. and on both of these logs the wide band is reading off the chart pig rich. Also notice how the 2g ecu reacts to knock and pulling timing. Not even close to how the 1g ecu handles knock.Thanks
Code:
</head>
<table x:str border=0 cellpadding=0 cellspacing=0 width=824 style='border-collapse:
 collapse;table-layout:fixed;width:619pt'>
 <col width=111 style='mso-width-source:userset;mso-width-alt:4059;width:83pt'>
 <col width=79 style='mso-width-source:userset;mso-width-alt:2889;width:59pt'>
 <col width=83 style='mso-width-source:userset;mso-width-alt:3035;width:62pt'>
 <col width=82 style='mso-width-source:userset;mso-width-alt:2998;width:62pt'>
 <col width=89 style='mso-width-source:userset;mso-width-alt:3254;width:67pt'>
 <col width=96 style='mso-width-source:userset;mso-width-alt:3510;width:72pt'>
 <col width=109 style='mso-width-source:userset;mso-width-alt:3986;width:82pt'>
 <col width=93 style='mso-width-source:userset;mso-width-alt:3401;width:70pt'>
  <td height=17 width=111 style='height:12.75pt;width:83pt'>TPS</td>
  <td width=79 style='width:59pt'>RPM</td>
  <td width=83 style='width:62pt'>TimingAdv</td>
  <td width=82 style='width:62pt'>AirFlow</td>
  <td width=89 style='width:67pt'>O2Sensor</td>
  <td width=96 style='width:72pt'>O2Sensor2</td>
  <td width=109 style='width:82pt'>AirTemp</td>
  <td width=93 style='width:70pt'>InjDutyCycle</td>
  <td width=82 style='width:62pt'>KnockSum</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="27.843137254902">27.84313725</td>
  <td align=right x:num>138.38</td>
  <td align=right x:num="0.72150000000000003">0.7215</td>
  <td align=right x:num="5.7333333333333298">5.733333333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="38.039215686274503">38.03921569</td>
  <td align=right x:num>207.57</td>
  <td align=right x:num="9.1733333333333302">9.173333333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="57.647058823529399">57.64705882</td>
  <td align=right x:num>2718.75</td>
  <td align=right x:num="2.6909999999999998">2.691</td>
  <td align=right x:num>10.44</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="83.921568627450995">83.92156863</td>
  <td align=right x:num="2.7494999999999998">2.7495</td>
  <td align=right x:num="10.893333333333301">10.89333333</td>
 </tr>
  <td align=right x:num>25</td>
  <td align=right x:num="1.5794999999999999">1.5795</td>
  <td align=right x:num>11.02</td>
 </tr>
  <td align=right x:num="11.1466666666667">11.14666667</td>
 </tr>
  <td align=right x:num>289.34</td>
  <td align=right x:num="1.677">1.677</td>
 </tr>
  <td align=right x:num="2.613">2.613</td>
  <td align=right x:num="11.866666666666699">11.86666667</td>
 </tr>
  <td align=right x:num>301.92</td>
  <td align=right x:num>12.46</td>
 </tr>
  <td align=right x:num>13.2</td>
 </tr>
  <td align=right x:num>320.79</td>
  <td align=right x:num="0.81899999999999995">0.819</td>
  <td align=right x:num="2.6715">2.6715</td>
 </tr>
  <td align=right x:num>333.37</td>
  <td align=right x:num="2.3205">2.3205</td>
  <td align=right x:num="13.953333333333299">13.95333333</td>
 </tr>
  <td align=right x:num>339.66</td>
  <td align=right x:num>14.72</td>
 </tr>
  <td align=right x:num>352.24</td>
  <td align=right x:num="1.911">1.911</td>
 </tr>
  <td align=right x:num>364.82</td>
  <td align=right x:num="1.8915">1.8915</td>
  <td align=right x:num>15.5</td>
 </tr>
  <td align=right x:num="1.8134999999999999">1.8135</td>
 </tr>
  <td align=right x:num>383.69</td>
  <td align=right x:num="16.466666666666701">16.46666667</td>
 </tr>
  <td align=right x:num>3000</td>
  <td align=right x:num>402.56</td>
  <td align=right x:num="1.7745">1.7745</td>
  <td align=right x:num>17.28</td>
 </tr>
  <td align=right x:num>415.14</td>
  <td align=right x:num>17.92</td>
 </tr>
  <td align=right x:num>427.72</td>
  <td align=right x:num="1.716">1.716</td>
  <td align=right x:num="18.753333333333298">18.75333333</td>
 </tr>
  <td align=right x:num>440.3</td>
 </tr>
  <td align=right x:num>452.88</td>
  <td align=right x:num="20.253333333333298">20.25333333</td>
 </tr>
  <td align=right x:num>3125</td>
  <td align=right x:num>478.04</td>
  <td align=right x:num="21.3333333333333">21.33333333</td>
 </tr>
  <td align=right x:num>490.62</td>
 </tr>
  <td align=right x:num>16</td>
  <td align=right x:num>515.78</td>
  <td align=right x:num="1.5209999999999999">1.521</td>
  <td align=right x:num="23.566666666666698">23.56666667</td>
 </tr>
  <td align=right x:num>534.65</td>
  <td align=right x:num>25.16</td>
 </tr>
  <td align=right x:num>3218.75</td>
  <td align=right x:num>559.81</td>
  <td align=right x:num>26.78</td>
 </tr>
  <td align=right x:num="1.3454999999999999">1.3455</td>
  <td align=right x:num="28.426666666666701">28.42666667</td>
 </tr>
  <td align=right x:num>3312.5</td>
  <td align=right x:num>616.42</td>
  <td align=right x:num="1.3260000000000001">1.326</td>
  <td align=right x:num="31.093333333333302">31.09333333</td>
 </tr>
  <td align=right x:num>641.58</td>
  <td align=right x:num="1.0529999999999999">1.053</td>
  <td align=right x:num="33.213333333333303">33.21333333</td>
 </tr>
  <td align=right x:num>3375</td>
  <td align=right x:num>685.61</td>
  <td align=right x:num>36</td>
 </tr>
  <td align=right x:num>717.06</td>
  <td align=right x:num>38.16</td>
 </tr>
  <td align=right x:num>754.8</td>
  <td align=right x:num="0.79949999999999999">0.7995</td>
  <td align=right x:num="40.3333333333333">40.33333333</td>
 </tr>
  <td align=right x:num>3468.75</td>
  <td align=right x:num>792.54</td>
  <td align=right x:num="0.40949999999999998">0.4095</td>
  <td align=right x:num>42.92</td>
 </tr>
  <td align=right x:num>3500</td>
  <td align=right x:num>836.57</td>
  <td align=right x:num="00.39">0.39</td>
  <td align=right x:num="45.546666666666702">45.54666667</td>
 </tr>
  <td align=right x:num>861.73</td>
  <td align=right x:num="0.2535">0.2535</td>
  <td align=right x:num>47.46</td>
 </tr>
  <td align=right x:num>868.02</td>
  <td align=right x:num="0.2145">0.2145</td>
  <td align=right x:num="47.533333333333303">47.53333333</td>
 </tr>
  <td align=right x:num>3625</td>
  <td align=right x:num="0.17549999999999999">0.1755</td>
  <td align=right x:num="47.173333333333296">47.17333333</td>
 </tr>
  <td align=right x:num>47.58</td>
 </tr>
  <td align=right x:num="48.393333333333302">48.39333333</td>
 </tr>
  <td align=right x:num>3750</td>
  <td align=right x:num>48</td>
 </tr>
  <td align=right x:num>880.6</td>
  <td align=right x:num="49.613333333333301">49.61333333</td>
 </tr>
  <td align=right x:num>886.89</td>
 </tr>
  <td align=right x:num>3843.75</td>
  <td align=right x:num>50.02</td>
 </tr>
  <td align=right x:num>3906.25</td>
  <td align=right x:num>912.05</td>
  <td align=right x:num="51.6666666666667">51.66666667</td>
 </tr>
  <td align=right x:num>924.63</td>
 </tr>
  <td align=right x:num>930.92</td>
  <td align=right x:num="52.493333333333297">52.49333333</td>
 </tr>
  <td align=right x:num>4000</td>
  <td align=right x:num="52.906666666666702">52.90666667</td>
 </tr>
  <td align=right x:num>4031.25</td>
  <td align=right x:num>943.5</td>
  <td align=right x:num>53.32</td>
 </tr>
  <td align=right x:num>4093.75</td>
  <td align=right x:num>949.79</td>
  <td align=right x:num="54.146666666666697">54.14666667</td>
 </tr>
  <td align=right x:num>962.37</td>
 </tr>
  <td align=right x:num>974.95</td>
  <td align=right x:num="55.386666666666699">55.38666667</td>
 </tr>
  <td align=right x:num>981.24</td>
  <td align=right x:num>56.28</td>
 </tr>
  <td align=right x:num>993.82</td>
  <td align=right x:num>56.7</td>
 </tr>
  <td align=right x:num>4250</td>
  <td align=right x:num="58.026666666666699">58.02666667</td>
 </tr>
  <td align=right x:num>4312.5</td>
  <td align=right x:num>1018.98</td>
  <td align=right x:num>58.88</td>
 </tr>
  <td align=right x:num>1031.56</td>
 </tr>
  <td align=right x:num>4375</td>
  <td align=right x:num>1037.85</td>
  <td align=right x:num="60.6666666666667">60.66666667</td>
 </tr>
  <td align=right x:num>1044.14</td>
  <td align=right x:num>61.1</td>
 </tr>
  <td align=right x:num>1063.01</td>
  <td align=right x:num="61.966666666666697">61.96666667</td>
 </tr>
 </tr>
  <td align=right x:num>4500</td>
  <td align=right x:num>62.4</td>
 </tr>
  <td align=right x:num>4531.25</td>
  <td align=right x:num>63.8</td>
 </tr>
  <td align=right x:num>64.24</td>
 </tr>
  <td align=right x:num>4593.75</td>
  <td align=right x:num>1094.46</td>
  <td align=right x:num>64.68</td>
 </tr>
  <td align=right x:num>1107.04</td>
  <td align=right x:num>65.12</td>
 </tr>
  <td align=right x:num>4687.5</td>
  <td align=right x:num>66</td>
 </tr>
  <td align=right x:num>1113.33</td>
 </tr>
  <td align=right x:num>1119.62</td>
  <td align=right x:num="65.866666666666703">65.86666667</td>
 </tr>
  <td align=right x:num>4781.25</td>
  <td align=right x:num>66.3</td>
 </tr>
  <td align=right x:num>1125.91</td>
  <td align=right x:num="65.706666666666706">65.70666667</td>
 </tr>
  <td align=right x:num>4843.75</td>
  <td align=right x:num="66.133333333333297">66.13333333</td>
 </tr>
  <td align=right x:num>66.56</td>
 </tr>
  <td align=right x:num>4906.25</td>
  <td align=right x:num="66.986666666666693">66.98666667</td>
 </tr>
 </tr>
  <td align=right x:num>1163.65</td>
  <td align=right x:num>67.84</td>
 </tr>
  <td align=right x:num="68.266666666666694">68.26666667</td>
 </tr>
  <td align=right x:num>5031.25</td>
  <td align=right x:num="68.6933333333333">68.69333333</td>
 </tr>
  <td align=right x:num>1195.1</td>
  <td align=right x:num="69.766666666666694">69.76666667</td>
 </tr>
  <td align=right x:num="70.633333333333297">70.63333333</td>
 </tr>
  <td align=right x:num>5125</td>
  <td align=right x:num>72.16</td>
 </tr>
  <td align=right x:num>1226.55</td>
  <td align=right x:num="71.066666666666706">71.06666667</td>
 </tr>
  <td align=right x:num>5187.5</td>
  <td align=right x:num>1213.97</td>
  <td align=right x:num="71.933333333333294">71.93333333</td>
 </tr>
  <td align=right x:num>5218.75</td>
  <td align=right x:num>1232.84</td>
  <td align=right x:num="72.366666666666703">72.36666667</td>
 </tr>
  <td align=right x:num>72.8</td>
 </tr>
  <td align=right x:num>1239.13</td>
  <td align=right x:num="73.233333333333306">73.23333333</td>
 </tr>
  <td align=right x:num>5312.5</td>
  <td align=right x:num="73.6666666666667">73.66666667</td>
  <td align=right x:num>2</td>
 </tr>
  <td align=right x:num>1258</td>
  <td align=right x:num>74.1</td>
 </tr>
  <td align=right x:num="74.533333333333303">74.53333333</td>
 </tr>
  <td align=right x:num="73.386666666666699">73.38666667</td>
 </tr>
  <td align=right x:num>74.24</td>
 </tr>
 </tr>
  <td align=right x:num="75.093333333333305">75.09333333</td>
 </tr>
  <td align=right x:num>5531.25</td>
  <td align=right x:num>75.52</td>
 </tr>
 </tr>
  <td align=right x:num>1289.45</td>
  <td align=right x:num>75.18</td>
 </tr>
  <td align=right x:num>5625</td>
  <td align=right x:num>1276.87</td>
  <td align=right x:num>75.6</td>
 </tr>
  <td align=right x:num>1295.74</td>
  <td align=right x:num>76.02</td>
 </tr>
  <td align=right x:num>3</td>
 </tr>
  <td align=right x:num="75.287499999999994">75.2875</td>
  <td align=right x:num>76.86</td>
 </tr>
 </tr>
  <td align=right x:num>5750</td>
  <td align=right x:num>77.28</td>
 </tr>
  <td align=right x:num="76.466666666666697">76.46666667</td>
 </tr>
  <td align=right x:num>5812.5</td>
  <td align=right x:num>76.88</td>
 </tr>
  <td align=right x:num="77.293333333333294">77.29333333</td>
 </tr>
  <td align=right x:num="76.046666666666695">76.04666667</td>
 </tr>
  <td align=right x:num>1314.61</td>
  <td align=right x:num="76.453333333333305">76.45333333</td>
 </tr>
 </tr>
  <td align=right x:num>5937.5</td>
  <td align=right x:num="77.266666666666694">77.26666667</td>
 </tr>
  <td align=right x:num="77.673333333333304">77.67333333</td>
 </tr>
  <td align=right x:num>76.8</td>
 </tr>
  <td align=right x:num>6031.25</td>
  <td align=right x:num>77.2</td>
 </tr>
 </tr>
  <td align=right x:num>77.6</td>
 </tr>
  <td align=right x:num>78</td>
 </tr>
  <td align=right x:num>6125</td>
  <td align=right x:num="77.093333333333305">77.09333333</td>
 </tr>
  <td align=right x:num>78.8</td>
 </tr>
  <td align=right x:num="77.486666666666693">77.48666667</td>
 </tr>
  <td align=right x:num>77.88</td>
 </tr>
  <td align=right x:num>6218.75</td>
  <td align=right x:num>79.6</td>
 </tr>
  <td align=right x:num="78.273333333333298">78.27333333</td>
 </tr>
  <td align=right x:num="78.6666666666667">78.66666667</td>
 </tr>
  <td align=right x:num>6281.25</td>
  <td align=right x:num>79.06</td>
 </tr>
  <td align=right x:num="79.453333333333305">79.45333333</td>
 </tr>
 </tr>
  <td align=right x:num>78.88</td>
 </tr>
 </tr>
  <td align=right x:num="80.633333333333297">80.63333333</td>
 </tr>
 </tr>
  <td align=right x:num>6468.75</td>
  <td align=right x:num>80.04</td>
 </tr>
 </tr>
  <td align=right x:num="80.426666666666705">80.42666667</td>
 </tr>
 </tr>
  <td align=right x:num>79.42</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="38.431372549019599">38.43137255</td>
  <td align=right x:num="61.0133333333333">61.01333333</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num="14.117647058823501">14.11764706</td>
  <td align=right x:num="0.5655">0.5655</td>
  <td align=right x:num>15.68</td>
 </tr>
  <td align=right x:num>245.31</td>
  <td align=right x:num="0.58499999999999996">0.585</td>
  <td align=right x:num="1.9890000000000001">1.989</td>
  <td align=right x:num>11.46</td>
 </tr>
  <td align=right x:num>37</td>
  <td align=right x:num>220.15</td>
  <td align=right x:num="9.8666666666666707">9.866666667</td>
 </tr>
  <td width=111 style='width:83pt'></td>
  <td width=79 style='width:59pt'></td>
  <td width=83 style='width:62pt'></td>
  <td width=82 style='width:62pt'></td>
  <td width=89 style='width:67pt'></td>
  <td width=96 style='width:72pt'></td>
  <td width=109 style='width:82pt'></td>
  <td width=93 style='width:70pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
What unit of measurement is that airflow in? It almost looks like it is reading in Hz, as nothing else correlates to those types of numbers. Did you get the 30 lb/min reading from the actual logger itself somewhere?
It looks like by the end of the pull at least, you were in the 1.6 g/rev - 1.8 g/rev range though, not 2.1 g/rev.
All in all, that knock looks negligible given that it is KnockSum and not degrees of timing retardation. As it is, the log looks fairly clean. Your issue with knock when pulling more airflow may signify that it is dropping you to an even lower timing map (1.4 g/rev), and the timing advance there (24* peak) is too aggressive, which is what's causing your knock.
You mentioned that you were looking into running straight E85? Drive around and tune your LTFTLo and LTFTMid to a decent percentage, which should get you close to your correct global fuel modification. I suspect that you may actually end up only needing to pull around 20% airflow in this case, which seems like it would work out well for you. Remember, always tune for good closed loop operation first before focusing on WOT.
The airflow in that log is in hz. What I have been doing is doing a log in evoscan then doing a log without touching a thing back to back with my pocket logger logging lbs/min. Sorry those numbers I had posted were before the afc correction. The lbs/min after the correction of the afc is 23.75lbs/min with the correction on the afc of –23. So using 23.75/(1-.23) or 30/.77 = 30.8lbs/min then taking (30.8*454)/6500 gives me 2.15g/rev. So after the correction I would be at 1.65g/rev. The thing about the knock is that in the –23 on the afc log you can see right at 4906.25rpm it starts to knock and pull 1 degree of timing till 5125rpm then at 5312 it pulls timing 1 degree till 5375 then what I don't get is that after that the knock goes up but the timing keeps on advancing??? Do not understand why? The units on the software reads the knock in counts but the excel file that I pull the columns off of shows it like you see it in the log. Below is a pic of a screen shot that shows what I am talking about. What is the difference? Are counts just raw data and sum is an estimate? On the tuning I always get a good partial throttle (closed loop) tune before I go WOT tuning, on the logs above on the lo and mid I was at 93on the Lo and 95 on the Mid. Thanks for all the info 2ggsx I really appreciate it. Thanks
I believe they are one in the same, with count(s) being the unit of measurement. The reason why your timing holds/goes up even though knock stays constant or gets worse is because right around that point you jump from (as seen by the ECU) ~1.8 g/rev to just below it, and thus shift timing maps.
Your timing is still being retarded by the knock, however you have a net gain in timing still because of the shift to a lower timing map. Your airflow/unit time deadlines fairly early, as it should being that it's a 16g, which means that g/rev (load) will decrease as RPM increases.
Was wondering how you were getting the g/rev thru the rpm band from the selected items in the data log? Is there was a formula you were using to get the g/rev from the Hz airflow and other items in the log? Or is it a guestimate? Would really like to know. Also there is another item I can log its airflow/rev was wondering if you know how to convert this to lbs/min or g/rev? The eval/function to get the value is 200*X/255. Thanks again
Pure guess-timation! I noticed that if you take Hz/(airflow) you get a very good approximation when under similar sets of circumstances. In your case, I used 55 hz/(1 lb/min). I wouldn't rely on this too much though, as I'm not sure if it varies based on intake temps, charge temps, baro, etc. It does seem to work oddly well for me though (and on a case-by-base basis, meaning not between different cars).
It's getting very weird that you post right before I log on. I think this was the third time in a row it's happened!
Don’t know, Psychic I guess. So do you think I should tune for some knock or no knock. The man who created evoscan (Hamish) told me that up to 5 counts was safe anything over ten was getting dangerous. What do you tune for?
I always tune for zero. Unfortunately, that never seems to be the case :p so I settle for 4 "counts" of knock. Technically though, no knock is safe, since any knock has a really violent effect on what goes on within your cylinders.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
