Arkansas members
With the initial break in was a little chatter, after 300 miles, probably less, it went away. Was really grippy too, but now it feels almost as stock with a little heavier peddle, not much though.
Hmmm. .... Might look into one and save the southbend for the 2.3 build.
Now....I need to find a 14b or a 16g.
Hmm. Happy for ya brandon. I haven't event touched the 2g. But when I do, I was thinking going stroker 2.2 or 2.3 myself. Everything will get took apart. Put into bags and documented. This will not be a DD. But a whole other animal. I just hope tge block is good. I haven't even looked at it.
May take 5+ yrs after im out of school. O well, im in no hurry.
Enjoy the white devil. Or whatever you decide to call it. ;)
Don't worry. Il change my picture here shortly. So you can have the only 1g active member exclusively.
Hey Alex, how much on the bushmaster?
Make me a reasonable offer. Not looking for brand new price by any means.
Comes with a Bushnell Red dot scope. As well as one mag, some 223 rounds, a few Zombie Spec 5.56 (for the hell of it), and a soft case. ;D
Was curious why you didn't just text...until I realized that I changed my number. Lol. I'll shoot you a text. (Pun Intended.)
I got figure out y the dash light arent working.
got me man, But all the gauges work, well... except for the OIL Pressure. the front case i installed on the car did not come with a sending unit. or even a place to install on for that matter, a aftermarket one may also be required.
FS:evo maf, 2g ecu, 2g manifold, ostrich, 14b - DSM Classifieds
well got it turned over gotta fix a oil leak in the back, and make it run better its running rough.
So I did a little tinkering in the garage early this morning ( its too damn hot during the day) wiring up my Glowshift red digital gauges, boost and egt, into my OBX cluster pod. I gotta say they seem to be nice quality. The pod is nice too it even has a factory style texture. Also threw on my voodoo3 mbc once it all goes back together.
Now to start pulling the tranny tonight....
No emission bullshit in the A state. Now tge exhaust situation is another thing. Haha. Ran out of funds.
well we r tryna everything before swapping the heads.
You might get it to hold for a little while. But without all 3 bolts holding that rail down.... might work for a month or a day. That might be where your rough idle is. I had it purring th day before the incident.
idk well see tomorrow. just got let that stuff dry.
The car motor trans and ecu are gone but everything else is there, including extra body parts, the rotas that are on the car, a 1g cylinder head and some other odds and ends
The engine, huh? Should have told me last week. I was looking for a 6 bolt bottom end. :) What do you want for it?
And what other odds/ends do you have? Ah! Do you have the rear chassis trans mount? The one that bolts to the body, not the trans. I need one.
Forgot a comma, the engine is in Idaho LOL. I might have it but for 500 you could have the whole shell, just bring your own wheels
I do have a 6 bolt block that might bore and clean up. I would throw it in
I just need the rear engine/chassis mount, and depending maybe some other odds and ends you have lying around. Cash in hand and can come today. Just indulge me.
