V8Killer25
- 368
- 0
- Oct 22, 2011
Little Rock,
Arkansas
I need a fmic with all piping for about 200?
not leaving just taking a break i guess. and i have a fmic and piping if you have a 14b or 16g with a j pipe style output. its pretty big also
So what's the deal with the car?
how much?
oh well anyone want a 7 bolt engine and a awd sheptrans
Hope it helps.What year ECU is it? 95-96?
If so, not only do you need to set the Invert CAS option in Link, you need to change your firing order from 4-1-2-3 to 2-3-1-4. If you don't do this, IF it ever starts it will sound like a tractor.
If you need any help with Link, give me a call tomorrow. 870-476-3029. I'm off all day. If you have internet available on your laptop then I can actually even remote in and take control of the program and adjust everything for you. Might have to walk you through adjusting your Throttle body, also.
Hope it helps.
When I get home I am going to switch the cop wiring. I still think I have a issue with either the ECT or the plug. I found the specs and will check the sensor and the wiring from the ecu to the plug.
Update:
Switched the pins to the power transistor and the car started right up.
Im still having issues with the coolant sensor. Its still showing -74 F so I know thats what is causing the car to run rough but at least I got it started.
Now I just need to find out what is wrong with the ECT...
Also how do I check the CEL?
When I first truned the key on it came on for about 6 seconds and went off. Started the car and now its staying on.
The CEL did go off untill I started the car... now it stays on.
I rewired the car and its running now. Still having issues with the ETC sensor. Its still showing -74 F
Was able to drive the car today. Its running ok, I still have to get the tuning better. Im getting knock retard when making a small pull. Still cant get the ECT to work, I am going to switch it out this weekend and see if that fixed it.
Also going to get a good log tomorrow to post up for help. I know it has lot to go but its good to hear it run.
