Arkansas members
Luke, how did your car react when you had the oil pump balance shaft out of phase?
I'm a little jealous actually :)
Sounded like hell but ran. I never drove it. It started and idled but I shut it off immediatley. Maybe 5-9 seconds top.
Well. Got my head off and idk why it started running the way it did...head seemed good, head gasket was good and block so far looks in decent condition. Little notch in cylinder 4 but it wouldn't have ran like it did with that. Gonna pull the block now and see if I find anything else wrong. Any input?
Well it was running prior to the tear down but I would have the head checked to make sure that isn't the problem before removing the block. Could be burnt valves in the cylinder not making the compression. If there isn't a hole in the piston then that eliminates the pistons. bad rings would smoke like a train due to oil getting in the combustion chamber. Anything lower than the piston isn't going to affect compression unless you have a broke rod BUT I'm sure that would be a no brainer and you would have pulled the engine from jump street.
I literally just pulled them all out by simply pulling on them, but one was somewhat tight. The one that saved the day. The crank bearings have very little wear, but I'm going to go ahead and replace them all with the ACL race kit. That was definitely the sound in the video LOL.
http://www.extremepsi.com/store/product.php?productid=23221&cat=0&page=1
Can someone help me clarify what this set contains. I know it has main and rod bearings, but does it come with the thrust bearings? It asks for block year, and sizes of rod and main bearings.
hmm I need to get socket sodered in my pcm... anyone got steady hands I got the stuff to soder it. My car is running hot and with fans blairing its not getting cooler... I think it might be the water pump... I pressure tested the cooling system never lost a psi over 10 minutes holding pressure... I think the impeller blades on the water pump broke some how and its not moving coolant like it should. Im going to do the water pump and my depowered rack at the same time so I don't have to reinstall the power steering pump.
I actually used to offer Soldering services here. Mail er' on over. Or I may swing by the area sometime in the near future.
https://www.youtube.com/watch?v=s3ctcF9Oxuo
Now I have somewhat of a video. Not the greatest but I was holding the phone and doing 130+ . Poor Acura thought because he had HID's and a fart pipe he was fast. LOL !!!!!!!!!! Sad thing was this was the second time I got him. I was head to head the first time and I left him sitting . The video here was I let him go by and wanted to run him down. You can hear him accelerating just as I am getting past but it's only for a second ROFL He wouldn't pull back up to me before I had to exit....
Best thing about getting off at 12:30 AM is cops are scarce
I was thinking he spent some time in the joint. You'd be surprised what they can do with a butter knife.:hmm:
And possibly previous military experience to boot ;)
My god! Lol look at those flywheel bolts!! Lol took the clutch off and didn't touch the bolts when I took this pic.
WTF ARPs in your future?
FINALLY! IT'S ALIVE! After months and months and months of working on her and years of storage time while going to a culinary university... She's back! Finished the last few needed bolts about 20minutes ago and enjoyed the first drive under boost in a long time. God I missed AWD.
Ignore how dirty she is... Needs a good wash.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
