Are they the same master cylinder?
meliketoball
1,505
5
Jan 4, 2007
Bay Area, CA, California
Hey I was wondering if the master cylinder push rods in a 420a the same as the 4g63s master cylinder? I bent my push rod to hell because I didn't put any loctite on the threads when I was putting it back on so it moved out of place then I ended up bending the push rod.:( So I'm wondering are they the same because they don't sell the push rods in kragens or autozone.
Did you mean the clutch master or the brake master?
If its the clutch master than they are the exact same part. If its the brake master I know that the only diference on 2g FWD's is whether or not they have ABS. Both the turbo and non turbo FWD 2g's share the same brake masters.
It's cool. I found that out by pulling a 420a master cylinder clutch push rod and using that for my 4g63.:D
