Chipper308
- 178
- 0
- Dec 10, 2012
Bay City,
Michigan
Aprox Lifespan on a Wideband??
If it goes bad can u keep the gauge and just replace the sensor??
yes the wideband o2 is easily replaced as any stock o2. The life depends on the placement of the o2/ 36 inches from turbo is normal and everyone uses it. before the flexpipe is also key.
Yeah, just a new sensor. The sensors with the innovate style plug can be had for $50-60. You can get the AEM style ones too, but I've never purchased them. Had a friend that worked at Oriley's that could.get the lC-1 units for $35. Should.have gotten 2 or 3.
The wrx sti stock sensor is a direct plug and play replacement for the AEM UEGO wideband.
Just double checked. 2000 subaru impreza. Not sure if it has the same harness, might need to be spliced in, but it works the same and you can pick it up from a local parts store.
Been doing some reading and it seems that the Bosch 17018 is the same as the AEM sensor. I will pull one at work tomorrow to check visually
Ill check that out, cause I work at Autozone
Discounts ftw!
