APFR Readings
mikelv
566
12
Jun 17, 2006
Columbus, Georgia
Would the APFR gauge produce/read stock psi (43psi) when the car is not running and fuel pump is on? (Switch on with DSMLink)
I am assuming yes, but I need to ask this stupid question anyways. My knowledge base has perished some over the years of not touching the car.
Yeah that's what I thought, it's not reading jack. I pulled the line and put it in a gas tank to see the flow. It's pouring like an old man with prostate issues.
If I have voltage drop problems, would that cause it? The pump not getting the proper voltage to run it at full power?
i would imagine voltage drop would make it do that but im not 100%. its like when you have voltage issues on a starter unless it has 11v or more it wont turn over like it should.
What's your battery voltage reading via link when you're activating the pump? It sounds like you said you're having low voltage issues, so if the battery is low, the pump will be low.
Try charging the battery, making sure you're seeing high 13's or low 14's for voltage, and activating it again to see what flow is like. If it still sucks, you might have a kink or restriction/clog.
if your battery isnt low on voltage you might need new or bigger gauge power wire to the pump. i would get a voltage meter and follow the wire back to the tank and see how much it is dropping off if any. like brian said check your battery first and go from there.
Yeah, my dumb ass drilled a hold right through a return line trying to drill a hole for a ground, right below the rear seats...yep on top of the gas tank, like an idiot.
Now I have to drop the tank today in order to replace it. Hope it's not too much of a pain.
My reasoning now is that the system is depressurized cause there is a big friggin hole in the line....
The line that is on top, centered.
Is that the pressure release valve or a component of the fuel return? That is the line that was damaged.
Does that have anything to do with compromising fuel pressure?
I have a brand new red top, alternator, and 0-gauge wiring. The highest the red top was putting out was 12v. The fuel pump was getting 12v, both when cranking.
Both readings were from a multimeter.
I'm running 8-guage power and ground wire for the pump. It's a 255, re-wired. I think it's either the line or a clogged fuel filter.
The filter is quite new, an aftermarket Aeromotive....but it has been sitting a couple years, so I'm not sure. Either way, the rail is only getting like 12psi.
Well regardless of what operates the pump in respect to the key/on. I was turning on the pump with dsmlink, so there is no question the pump
was operating. I had to take a break last night from the car. I'm gonna take the damn tank off
tonight and take a look and see.
