APEXi SAFC II questions/help...
mwracing
Feb 6, 2006
Vancouver,
ok... make this quick.
i am getting really poor fuel economy. like 50Liters gives me 325km. feels like im running really rich or something isnt right.
i have 550cc denso injectors
255lph rewired fuel pump.
MAF-T with dials Zero'd out, and set to 3" GM MAS and 550cc.
i just bought a Apexi SAFC 2.
I havent installed it yet... it is still in the box, but reading the instrucions for my car it says my mitsubishi preset maps are for a karman vortex MAS setup (stock) is there anything i need to adjust or do differently if i have a MAF-T instead of a stock MAS?
and also..
i can wire it no problem... but after that once the power is on, i have no idea what the settings mean, how to start or even get started, what to look for, how to log/view and just general operation of basic tuning and furthermore....
im running a evo3 16G, mbc @ 16lbs, large FMIC, Blitz BOV, SS tubular exhaust mani, SS o2, ss 3" back with no cat.
look in profile for more details....
Change your settings to :
Sensor Type: Karman
Cyl: 4
Throttle : arrow towards NE (basically up)
Lo and Hi: You must get a datalogger to tune these. Follow the tech articles to do so. Most common Th points are at the thousands and half way marks. Also, Since your MAF-T is semi-compensating for your injectors, plug your logger in (do you have wideband) and see if you can lean her out a bit. Chances are you are still running pig rich. DO NOT go mroe than -5% lean if you do not have a logger/WB.
