Apexi S-AFC ?
98GSXboosted
166
3
Oct 3, 2005
oxford, Massachusetts
I have two questions regarding my Safc, can i program it so i can vent my BOV?
Also i want to know how to navigate through the menu on the safc, i dont have the insruction manual and the apexi website adobe tech info isn't working. i wnat to change the display but i dont want to mess anything thing up, do i just hold the button left, right, up, or down?
Man your lucky I'm nice.
First no bumping your post, in any form.
Second can't help with the instructions, just go on there web site and it may be there. Someone else may be able to help you out there.
Third YOU CAN'T VENT YOU BOV only using a SAFC. You need a blow-thru setup to do that or get rid of the mas all together ex AEM EMS. If you don't have a clue of what I'm talking about, you need to search.
If you really want to vent the cheapest way to do it RIGHT is a GM MAFT, again if you have no clue what that is SEARCH.
Trust me I'm a lot more patient than most, but you will find that out soon enough.
Derek :dsm:
Once again I will be nice.
http://www.dsmtuners.com/forums/showthread.php?t=204277&highlight=SAFC
Don't hook up the purple knock sensor wire. It won't work. The only way for you to see knock is to get dsm link, or a stand alone or knock box. Do you have a logger? If so you tune for timing advance not knock. And that reading is wrong, knock is bad, and 20-40counts would really pull your timing down.
Just don't hook that wire up and ignore that reading.
Derek :dsm:
Is your profile up to date?
