apexi S-AFC ll
1gnew
Jun 16, 2010
pERU, Indiana
so i have just acquired an apexi safc 2 and am wondering i know i need this to help with fuel management but what does it really do i have search the forum and haven't seen anything can some one help me and tell me what this thing all does
This extremely fine piece of electronic hardware allows you to fine tune your air/fuel adjustments to your vehicle while taking in the consideration of your vehicles LT/ST fuel trim over periods of time. In more simple terms it allows you to lean out or richen up your fuel delivery. And BTW its pretty much a shot in the dark unless you have a way to read your LT/St fuel trims. Via Pocketlogger, DSM link, Etc..
Even Better = http://www.dsmtuners.com/forums/articles-tuning-ecu/366004-safc-tuning-how-why.html
i have searched for a logger and have come up empty and suggestions
i have a 2g maf and a plug and play adapter i got off ebay will i be able to a just the fuel accordingly for the increase in airflow with this safc 2
Dude look for a datalogger on the site it plugs into your obd port and allows you to record and view engine statistics hence fuel trims and adjust accordingly. I hace been using a craftsman engine scanner to record live data and adjust acoording to freeze frame data to ST/LT fuel trims. digital tuning, inc.
You will need atleast 550's or higher to run a 2G MAS on a 1G, and you will need a datalogger and wbo2 and a fuel pump if you don't have one or rewire your stock atleast. Google is your friend, you can find ANYTHING through Google if you just type..
i have this AFC unit in my 95 talon with 650cc injectors and a MHT EVO 3 16g turbo. my question is do i need it on there with those 2 upgrades?
Without a data logger or wideband you will have no idea where the settings need to be and you will likely blow your engine.
why are we bringing back 2 year old threads???
....you say that so matter of factly and dry that it's funny. Did it really need explaination?
ROFL
Bryan is right. You need something to tell you what that AFC is doing or you will wind up doing damage eventually.
