Apexi Neo AFC Help!
97moneyhole
30
Jun 12, 2005
Tecumseh, Kansas
Here is my problem. After installing my new apexi neo i can start my gst without any corrections being made. If you look at my profile you will see that i have 650 injectors so my car should idle like crap and then die at start up. My wide band shows at idle a mixture between 14.2 and 15.2. but as soon as i put it in gear and take off it goes pig rich and tries to die. (Yes, i believe that I have hooked it up right, i have also double and triple checked each wire.) :confused:
Side note:
If anyone is currently running this AFC please share with me your settings. I know every car is different but i would just like a place to start. LOW THL %, HI THL %, ect.
Thanks.
well i am going to tune it but i just thought it was a little weird that it would idle normal with zero corrections and 650 injectors.
thats what i mean, my car should not be idleing correctly, it should sputter and then die with "no corrections" everything is set at zero not -30.
Well it worked just fine before some little sh** ripped out my original SAFC. Now after installing my NEO i have these problems.
Ok, besides the chance that my Wideband is bad, I said screw it and took it out for a drive. i used the settings that i wrote down from my original SAFC. I have it tuned up to 4,000 rpms but the car bucks hard at 5,000 and on, no matter the correction %.(i need a logger bad)
