anyone with a gst autocrosses?
95'EclipseGST
Jul 10, 2010
Woodbridge, New Jersey
Anyone own a gst that autocrosses and put down good times? What kind of suspension work do you have done and is your motor built at all?
What do you want to know really?
I autocross but I would hardly be considered an expert. Some Tokico HPs with Eibach Pro-kits helped quite a bit, but the best mod I've ever done is wider rubber.
Bear in mind before doing modifications what class you'll be put in. I'm currently in SM and my car just isn't competitive there because even though I have enough power my car would actually probably be faster with less power being that I'm so traction limited coming out of the corners that it is actually hard to keep the tires from spinning.
The key to being succesful with autocross is seat time and staying within your budget range as far as classes go. If you want to do good try and stay in a bracket that you can afford to have the best of every part that is allowed.
