anyone use glowshift gauges?
JeffDsM90
Jun 15, 2009
lithia springs, Georgia
I was wondering if anyone uses (ebay) glowshift gauges and how accurate are they? Any information would help. Thanks Jeff.
i have 2 and they have always worked great. as far as accuracy, i hooked up a glowshift boost gauge and an autometer and the glowshift only had about a .5+ psi difference, thats pretty good for a cheap gauge
i used to have a glowshift boost gauge, wideband... really accurate ...
now i use prosport gauges..
I was using 4 of them but the oil pressure and fuel pressure senders went out so now im back with autometer ultralights
I use to use the glowshift boost, oil pressure, and air/fuel gauges. The oil pressure and air/fuel gauge stopped working normally, and the boost gauge was off by about 1-2psi. I ended up replacing the glowshift boost gauge with a AEM tru-boost gauge type controller. The other two gauges were replaced with Prosport gauges.
All my Glowshift work great. The water temp gauge is just mildly off it seems though, maybe 5* not bad.
I have the Glowshift boost and oil pressure...was contemplating on getting the wideband or maybe the AEM UEGO...I know the AEM is tried and true because I had one in my GST I had before I deployed and I currently have one in my 1g GSX, which for now is a daily driver until I'm finished with my 2g. I do have one question though, does anyone know if the Glowshift wideband has a wire to run to the EGRT for use with MMCD? Figured it would make tuning a lil easier to be able to view it on my Palm
Thanks for the help everyone....I looked into the prosport and im most likely going to get them
