74runner
- 137
- 3
- Nov 21, 2009
Brantford,
ON, Canada
Hey guy's,
I'm looking to try this out of my own curiosity and not for any performance gain or looks.
I have a 1990 Eagle Talon awd tsi.
I have a C.O.P set up I pulled from a 2008 Mazda Protege and it's a 3 wire coil not 2 wire like everyone here uses.
Now before anyone slams me and says don't bother I'll tell you I've searched this a lot and see a lot of negative comments, I'm only interested in info that will help me and others, your opinions don't matter here.
On a 4 wire set up you have:
One wire is the common power feed from the ignition switch.
One wire is the common ground.
One wire is the "IGF" This wire sends a signal to the ecm telling it that the coil just fired.
One wire is the "IGT" ignition timing. This wire turns on the transistor inside the coil. And is the only wire not common to all four coils.
I'm guessing I could just remove the "IGF" wire because my ecm won't see it's signal any way and I assume I can run the coils like a 2 wire set up?
38 views and no comments?
I guess no one has any thing nice to say
