Anyone try the ebay fuel pump rewire kit?
I installed the 190 walboro...along with the ebay rewire.I have to say im pretty satisfied.
I actually had a no start issue and lost the cel after pulling the cables off the battery.I thought my no start was because of the fuel pump not priming with the key turned.Thats why i installed the 190 and did the rewire...
My problem ended up being a couple of bent exhaust valves...i wasnt getting coolant into the block for some reason, and my gauges werent reading anything out of the norm.
The weird thing is...after getting my valves fixed, and after installing the 190 and the rewire kit, i dont hear the fuel pump prime anymore with the key turned prior to starting the car.
I dont know ha ha.Besides that weirdness im pretty happy with the rewire kit.
Just be sure if you buy the pump off ebay that its actually a Walboro...lot of junk remakes going around on there.
As far as I understand it, there should be no "prime" in the stock wired system. The fuel pump I believe only comes active when the car is set to the "Start" position. So even with a rewire, the electronic control shouldn't initiate the fuel pump until you actually try to start the car.
This is correct.
I'm glad I saw this because I was going to order the ebay kit! good to see all you guys are having luck with it...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
