anyone mod the wastegate actuator?
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
Right now my actuator on my 16g is starting to open alittle at 5psi. I have a actuator from a t25 that I was thinking about cutting and putting a stiffer spring in there. I know It will need some work to fit on a 16g, But has anyone put a different spring in one?
Even with my mbc, it still opens early. I think my actuator is just goin bad.
Put some washers between the bracket and the turbo housing to preload the actuator.
This.
If you find an adjustable WG actuator, you can go that route. I recently hacked 1/2-3/4 of an inch off of mine as my WG was always open. I wondered where my spool went...
Well im gonna try and do it. I took it apart, just have to find a spring that fits and is stronger. Ill go to hardware stores tomm and see what they have. I will also be able to hold more boost ###### with a stiffer spring. Im goin for like 20psi to open it.
