WES_393
DSM Wiseman
- 3,814
- 98
- Jun 6, 2011
Colo Spgs,
Colorado
Only problem I see with that theory, Wes, is that if the mas cannot measure the air going back out and write it off as unused, then what exactly happens if you are recirculating your bov back into the turbo's intake, and it discharges the unused air? Its being discharged at the inducer side of a compressor with no drive pressure, slowing it, and being released the opposite way through the maf. I could be wrong here, but it seems to be the same in my mind
A little air discharging backwards through the MAF wouldn't be so bad, I'm sure that's what happens anyways when we chop the recirc tube and vent high pressure. The problem is the air being blown out of the MAF, and then getting sucked back in and counted again. You have X amount of air in the intake system that has been counted and will be consumed by the engine, but that air keeps oscillating back and forth through the MAF sensor and basically simulating a larger mass of air moving through it. Like a kid waving his hand across the door sensor and the dry cleaners to make that "bing-bong" noise. It's counting the same thing over and over, but the store owner thinks he just got 20 customers all at once.
I'll have to dig up my old logs from when I had a too heavily crushed 1g BOV. I have logs that show the difference between when the BOV opened, and when it caused flutter. I could let off the gas, listen to the surge, and literally watch the graph stutter and flatline.
goes inside it doesn't it?
