anybody ever use the Clutch masters flow control valve?
The stock slave cylinders come with one of these installed on the 2gs. Not sure if the 1gs do or not. Its just a little spring and a plate with a hole in it. I always take them out, it caused more chatter in my clutch by leaving it in. I wouldn't buy it.
I'm going to give you some advice. The first thing you should do is totally stop using that website. They are known for doing all kinds of crazy shit.
Those valves are for shitty drivers, all it does is cause the clutch to slip creating unnecessary wear to make cars that require fast shifts to shift more smoothly.
I use the factory 2g one. its not on the slave. its that separate reservoir mounted inline just before the slave. they are not useless. work very well with my tilton carbon carbon twin. and absolutely necessary with QM twin
