Any idea if these are PTE 680 injectors
BOBS90TURBO
581
5
Sep 18, 2002
Tulsa, Oklahoma
I just bought these, the guy said they are PTE 680's but they look a lot like the Fuel Injector Clinic Injectors. I will add pics.
The numbers 0275 17113744-95 along the top and rp near the tip.
I have had two sets of fic injectors and the only thing on them has been the size. My 750's have just 750 inscribed by hand on them.
FIC & PTE injectors are made by the same company, they differ with the tips. If you post a pic should be able to verify. FIC's have the flow engraved on the side (by hand), not sure about PTE.
I had a set of PTE 680s, they did not have the flow ont hem anywhere, but it did have some numbers / letters on it.
Mines looked exactly like that, numbers in the same position too.
You might want to resize those ASAP. cause otherwise the mod will do something >.>
Not that it makes much difference because PTE & FIC injectors are produced at the same place & its hard to tell with the lower insulator on but aren't those FIC's? PTE usually have a different end (from what I can see in the pics). Those size injectors will give you lots of room to grow, as long as you have dsmlink or an eprom ecu to control them with :thumb:
Enough time has been given.
