goodbuds
- 1,043
- 7
- Nov 10, 2009
oceanside,
California
Can yoy get me tickets
The fuel sliders will modify final AFR's in open loop at that given RPM, it has nothing to do with the load. If you subtract -2% across the board then you'll lean out the entire RPM band rather than at a given RPM/Load on a OLMaxOct map. The idea of getting your VE map tuned to perfection is so you only have to make changes to your OLMaxOct map to tune AFR's. Basically, you put a banana in and you get a banana out whereas if your VE map is all fvcked up you put a banana in and you get a apple back. If your SD VE map is tuned correctly whatever AFR you type in in your OLMaxOct map is what you'll see on your WB at WOT.only thing i really havnt figured out is, under SD do the fuel sliders modify final calcs also or do they become ignored ( IE: read only from VE table )
and for cruising/idle AFR's is that the Max/min oct map just for Target AFR's or what?
your giving away my secrets to success. you are killing me as if it wasnt public enough you got to go and post it out in the open in numerous places.
Please say your prayers for this poor DSM, I don't even know how this damn thing even starts. Watch the video from the beginning of the build...
‪Mitsubishi eclipse GSX (making off)‬‏ - YouTube
