ECMlink Anti lag??
1g Cam
77
Sep 16, 2014
Scottsbluff, Nebraska
I know the question has been asked a lot but i just want to do one launch on it and see what it's like I don't plan on doing it over and over launch control does enough. I have a full fuel system with 1000cc fics and an 18g greddy and an FP manifold no cat. I was wondering what i should start the settings at. I have used link so there was anti lag on the other car and it holds 20° thanks in advance
It will take several launches to get anti-lag setup so don't think you'll be able to check this out with only one launch. Anti-lag is hard on turbos. This is like saying you want to rev your motor to 15K just to check it out but you're not going to do it but only one time. I don't see the point.
Tune AFR to whatever your car should run in boost while retarding the timing until boost is created. Set the activation RPM high enough to where the turbo can spool and set the rev limiter ~500rpms above that.
Anti-lag IS hard on turbos and it set's timing to ATDC so the combustion partially happens in the turbine housing, that is WHY it is hard on them. Please correct me if I am wrong but usually 8-12* ATDC with fuel enrichment also.
