Chumpaumpalumpa
- 1,554
- 304
- Jun 16, 2014
La Habra,
California
So I was messing around with the ALS on V2 the other day to get acquainted with it better and to just see how it all worked together and I set the RPM launch limit at 4750 and under the ALS tab I set "use with launch RPM" to 3250 and I noticed I could build 20psi before I even hit the limiter. So my question is does the damage to the turbo from anti-lag mostly occur when you are bouncing off the limiter, or is it purely from retarding the timing and adding fuel?
