another newb with another log that needs help
justin0469
1,004
10
Apr 4, 2003
san diego, California
so i think i basically understand the concept, adjust fuel trims to be .92ish in every load (throttle position) for every range of RPMs. then if need adjust the timing to be from 10-15 degrees after TDC. take a look at this though, and let me know where to start, its pretty messed up. mods are 50trim, 720cc injectors, 255 pump, 6bolt bored out and built, cam gears, dont know what else matters. the ecu+ estimated hp is only 246 and torque at 262. i know a 50trim w/ supporting mods can do better then that. i have a boost controller and the greddy boost gauge i have says its gettin close to 1 bar (like 14.7 psi right?) but i dont konw how much boost i can run safely.
Code:
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
@page
	{margin:1.0in .75in 1.0in .75in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;}
tr
	{mso-height-source:auto;}
col
	{mso-width-source:auto;}
br
	{mso-data-placement:same-cell;}
.style0
	{mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	white-space:nowrap;
	mso-rotate:0;
	mso-background-source:auto;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	border:none;
	mso-protection:locked visible;
	mso-style-name:Normal;
	mso-style-id:0;}
td
	{mso-style-parent:style0;
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
</style>
<!--[if gte mso 9]><xml>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>RUN</x:Name>
    <x:WorksheetOptions>
     <x:Selected/>
     <x:ProtectContents>False</x:ProtectContents>
     <x:ProtectObjects>False</x:ProtectObjects>
     <x:ProtectScenarios>False</x:ProtectScenarios>
    </x:WorksheetOptions>
   </x:ExcelWorksheet>
  </x:ExcelWorksheets>
  <x:WindowHeight>15750</x:WindowHeight>
  <x:WindowWidth>28620</x:WindowWidth>
  <x:WindowTopX>120</x:WindowTopX>
  <x:WindowTopY>75</x:WindowTopY>
  <x:ProtectStructure>False</x:ProtectStructure>
  <x:ProtectWindows>False</x:ProtectWindows>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=846 style='border-collapse:
 collapse;table-layout:fixed;width:636pt'>
 <col width=64 span=2 style='width:48pt'>
 <col width=126 style='mso-width-source:userset;mso-width-alt:4608;width:95pt'>
 <col width=118 style='mso-width-source:userset;mso-width-alt:4315;width:89pt'>
 <col width=102 style='mso-width-source:userset;mso-width-alt:3730;width:77pt'>
 <col width=116 style='mso-width-source:userset;mso-width-alt:4242;width:87pt'>
 <col width=128 style='mso-width-source:userset;mso-width-alt:4681;width:96pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 width=64 style='height:12.75pt;width:48pt'>Time</td>
  <td width=64 style='width:48pt'>RPM</td>
  <td width=126 style='width:95pt'>Injector Pulse Width</td>
  <td width=118 style='width:89pt'>Injector Duty Cycle</td>
  <td width=102 style='width:77pt'>Throttle Position</td>
  <td width=116 style='width:87pt'>MAS Frequency In</td>
  <td width=128 style='width:96pt'>MAS Frequency Out</td>
  <td width=64 style='width:48pt'>Timing</td>
  <td width=64 style='width:48pt'>O2 Front</td>
 </tr>
  <td height=17 style='height:12.75pt'>secs</td>
  <td></td>
  <td>ms</td>
  <td></td>
  <td>volts</td>
  <td>Hz</td>
  <td>Hz</td>
  <td>degrees</td>
  <td>volts</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.2</td>
  <td align=right x:num>2013</td>
  <td align=right x:num>4</td>
  <td align=right x:num>6</td>
  <td align=right x:num>4.41</td>
  <td align=right x:num>256</td>
  <td align=right x:num>160</td>
  <td align=right x:num>19</td>
  <td align=right x:num>0.55</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.24</td>
  <td align=right x:num>2029</td>
  <td align=right x:num>258</td>
  <td align=right x:num>161</td>
  <td align=right x:num>26</td>
  <td align=right x:num>0.16</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.28</td>
  <td align=right x:num>1995</td>
  <td align=right x:num>4.48</td>
  <td align=right x:num>257</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.32</td>
  <td align=right x:num>1972</td>
  <td align=right x:num>4.1</td>
  <td align=right x:num>250</td>
  <td align=right x:num>156</td>
  <td align=right x:num>27</td>
  <td align=right x:num>0.09</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.36</td>
  <td align=right x:num>1993</td>
  <td align=right x:num>4.5</td>
  <td align=right x:num>255</td>
  <td align=right x:num>159</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.4</td>
  <td align=right x:num>2047</td>
  <td align=right x:num>0.08</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.44</td>
  <td align=right x:num>2095</td>
  <td align=right x:num>7</td>
  <td align=right x:num>4.49</td>
  <td align=right x:num>265</td>
  <td align=right x:num>166</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.48</td>
  <td align=right x:num>2106</td>
  <td align=right x:num>271</td>
  <td align=right x:num>169</td>
  <td align=right x:num>0.07</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.52</td>
  <td align=right x:num>2100</td>
  <td align=right x:num>4.53</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.56</td>
  <td align=right x:num>2096</td>
  <td align=right x:num>272</td>
  <td align=right x:num>170</td>
  <td align=right x:num>0.06</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.6</td>
  <td align=right x:num>2117</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.64</td>
  <td align=right x:num>2160</td>
  <td align=right x:num>4.54</td>
  <td align=right x:num>275</td>
  <td align=right x:num>172</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.68</td>
  <td align=right x:num>2191</td>
  <td align=right x:num>283</td>
  <td align=right x:num>177</td>
  <td align=right x:num>28</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.72</td>
  <td align=right x:num>2206</td>
  <td align=right x:num>4.58</td>
  <td align=right x:num>291</td>
  <td align=right x:num>182</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.76</td>
  <td align=right x:num>2216</td>
  <td align=right x:num>285</td>
  <td align=right x:num>178</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.8</td>
  <td align=right x:num>4.6</td>
  <td align=right x:num>288</td>
  <td align=right x:num>180</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.84</td>
  <td align=right x:num>2231</td>
  <td align=right x:num>4.2</td>
  <td align=right x:num>286</td>
  <td align=right x:num>179</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.88</td>
  <td align=right x:num>2263</td>
  <td align=right x:num>4.62</td>
  <td align=right x:num>293</td>
  <td align=right x:num>183</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.92</td>
  <td align=right x:num>2300</td>
  <td align=right x:num>8</td>
  <td align=right x:num>295</td>
  <td align=right x:num>185</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>22.96</td>
  <td align=right x:num>2322</td>
  <td align=right x:num>4.65</td>
  <td align=right x:num>300</td>
  <td align=right x:num>188</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23</td>
  <td align=right x:num>2321</td>
  <td align=right x:num>308</td>
  <td align=right x:num>193</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.04</td>
  <td align=right x:num>2337</td>
  <td align=right x:num>4.67</td>
  <td align=right x:num>312</td>
  <td align=right x:num>195</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.08</td>
  <td align=right x:num>2353</td>
  <td align=right x:num>313</td>
  <td align=right x:num>196</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.12</td>
  <td align=right x:num>2385</td>
  <td align=right x:num>4.7</td>
  <td align=right x:num>315</td>
  <td align=right x:num>197</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.16</td>
  <td align=right x:num>2401</td>
  <td align=right x:num>4.3</td>
  <td align=right x:num>325</td>
  <td align=right x:num>203</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.2</td>
  <td align=right x:num>2423</td>
  <td align=right x:num>4.74</td>
  <td align=right x:num>335</td>
  <td align=right x:num>210</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.24</td>
  <td align=right x:num>2448</td>
  <td align=right x:num>333</td>
  <td align=right x:num>208</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.28</td>
  <td align=right x:num>2464</td>
  <td align=right x:num>9</td>
  <td align=right x:num>4.75</td>
  <td align=right x:num>337</td>
  <td align=right x:num>211</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.32</td>
  <td align=right x:num>2486</td>
  <td align=right x:num>4.4</td>
  <td align=right x:num>344</td>
  <td align=right x:num>215</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.36</td>
  <td align=right x:num>2512</td>
  <td align=right x:num>4.76</td>
  <td align=right x:num>352</td>
  <td align=right x:num>220</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.4</td>
  <td align=right x:num>2522</td>
  <td align=right x:num>348</td>
  <td align=right x:num>218</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.44</td>
  <td align=right x:num>2549</td>
  <td align=right x:num>364</td>
  <td align=right x:num>228</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.48</td>
  <td align=right x:num>2572</td>
  <td align=right x:num>360</td>
  <td align=right x:num>225</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.52</td>
  <td align=right x:num>2584</td>
  <td align=right x:num>227</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.56</td>
  <td align=right x:num>2608</td>
  <td align=right x:num>366</td>
  <td align=right x:num>229</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.6</td>
  <td align=right x:num>2631</td>
  <td align=right x:num>10</td>
  <td align=right x:num>373</td>
  <td align=right x:num>233</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.64</td>
  <td align=right x:num>2657</td>
  <td align=right x:num>370</td>
  <td align=right x:num>231</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.68</td>
  <td align=right x:num>2666</td>
  <td align=right x:num>376</td>
  <td align=right x:num>235</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.72</td>
  <td align=right x:num>2687</td>
  <td align=right x:num>380</td>
  <td align=right x:num>237</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.76</td>
  <td align=right x:num>2713</td>
  <td align=right x:num>399</td>
  <td align=right x:num>249</td>
  <td align=right x:num>0.12</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.8</td>
  <td align=right x:num>2743</td>
  <td align=right x:num>385</td>
  <td align=right x:num>241</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.84</td>
  <td align=right x:num>2764</td>
  <td align=right x:num>395</td>
  <td align=right x:num>247</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.88</td>
  <td align=right x:num>2774</td>
  <td align=right x:num>407</td>
  <td align=right x:num>0.15</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.92</td>
  <td align=right x:num>2793</td>
  <td align=right x:num>402</td>
  <td align=right x:num>251</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>23.96</td>
  <td align=right x:num>2824</td>
  <td align=right x:num>11</td>
  <td align=right x:num>406</td>
  <td align=right x:num>254</td>
  <td align=right x:num>0.14</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24</td>
  <td align=right x:num>2848</td>
  <td align=right x:num>428</td>
  <td align=right x:num>268</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.04</td>
  <td align=right x:num>2870</td>
  <td align=right x:num>425</td>
  <td align=right x:num>266</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.08</td>
  <td align=right x:num>2886</td>
  <td align=right x:num>4.57</td>
  <td align=right x:num>420</td>
  <td align=right x:num>263</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.12</td>
  <td align=right x:num>2913</td>
  <td align=right x:num>4.8</td>
  <td align=right x:num>424</td>
  <td align=right x:num>0.37</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.16</td>
  <td align=right x:num>2936</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.2</td>
  <td align=right x:num>2954</td>
  <td align=right x:num>426</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.24</td>
  <td align=right x:num>2988</td>
  <td align=right x:num>4.9</td>
  <td align=right x:num>12</td>
  <td align=right x:num>434</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.28</td>
  <td align=right x:num>3018</td>
  <td align=right x:num>455</td>
  <td align=right x:num>0.52</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.32</td>
  <td align=right x:num>3035</td>
  <td align=right x:num>458</td>
  <td align=right x:num>287</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.36</td>
  <td align=right x:num>3058</td>
  <td align=right x:num>446</td>
  <td align=right x:num>279</td>
  <td align=right x:num>0.62</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.4</td>
  <td align=right x:num>3077</td>
  <td align=right x:num>453</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.44</td>
  <td align=right x:num>3093</td>
  <td align=right x:num>450</td>
  <td align=right x:num>281</td>
  <td align=right x:num>0.68</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.48</td>
  <td align=right x:num>3126</td>
  <td align=right x:num>462</td>
  <td align=right x:num>289</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.52</td>
  <td align=right x:num>3140</td>
  <td align=right x:num>5</td>
  <td align=right x:num>13</td>
  <td align=right x:num>486</td>
  <td align=right x:num>304</td>
  <td align=right x:num>0.77</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.56</td>
  <td align=right x:num>3160</td>
  <td align=right x:num>510</td>
  <td align=right x:num>319</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.6</td>
  <td align=right x:num>3186</td>
  <td align=right x:num>511</td>
  <td align=right x:num>320</td>
  <td align=right x:num>0.79</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.64</td>
  <td align=right x:num>3197</td>
  <td align=right x:num>5.1</td>
  <td align=right x:num>478</td>
  <td align=right x:num>299</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.68</td>
  <td align=right x:num>3225</td>
  <td align=right x:num>499</td>
  <td align=right x:num>0.81</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.72</td>
  <td align=right x:num>3254</td>
  <td align=right x:num>524</td>
  <td align=right x:num>328</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.76</td>
  <td align=right x:num>3285</td>
  <td align=right x:num>14</td>
  <td align=right x:num>4.55</td>
  <td align=right x:num>520</td>
  <td align=right x:num>0.84</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.8</td>
  <td align=right x:num>3304</td>
  <td align=right x:num>506</td>
  <td align=right x:num>316</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.84</td>
  <td align=right x:num>3327</td>
  <td align=right x:num>537</td>
  <td align=right x:num>336</td>
  <td align=right x:num>0.83</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.88</td>
  <td align=right x:num>3347</td>
  <td align=right x:num>517</td>
  <td align=right x:num>323</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.92</td>
  <td align=right x:num>3384</td>
  <td align=right x:num>5.3</td>
  <td align=right x:num>556</td>
  <td align=right x:num>0.85</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>24.96</td>
  <td align=right x:num>3403</td>
  <td align=right x:num>15</td>
  <td align=right x:num>535</td>
  <td align=right x:num>334</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25</td>
  <td align=right x:num>3436</td>
  <td align=right x:num>580</td>
  <td align=right x:num>363</td>
  <td align=right x:num>0.87</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.04</td>
  <td align=right x:num>3455</td>
  <td align=right x:num>5.4</td>
  <td align=right x:num>566</td>
  <td align=right x:num>354</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.08</td>
  <td align=right x:num>3480</td>
  <td align=right x:num>581</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.12</td>
  <td align=right x:num>3500</td>
  <td align=right x:num>5.5</td>
  <td align=right x:num>16</td>
  <td align=right x:num>585</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.16</td>
  <td align=right x:num>3530</td>
  <td align=right x:num>576</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.2</td>
  <td align=right x:num>3560</td>
  <td align=right x:num>5.6</td>
  <td align=right x:num>586</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.24</td>
  <td align=right x:num>3587</td>
  <td align=right x:num>632</td>
  <td align=right x:num>0.89</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.28</td>
  <td align=right x:num>3600</td>
  <td align=right x:num>5.7</td>
  <td align=right x:num>17</td>
  <td align=right x:num>653</td>
  <td align=right x:num>409</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.32</td>
  <td align=right x:num>3624</td>
  <td align=right x:num>4.56</td>
  <td align=right x:num>600</td>
  <td align=right x:num>375</td>
  <td align=right x:num>25</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.36</td>
  <td align=right x:num>3655</td>
  <td align=right x:num>5.8</td>
  <td align=right x:num>611</td>
  <td align=right x:num>382</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.4</td>
  <td align=right x:num>3688</td>
  <td align=right x:num>5.9</td>
  <td align=right x:num>18</td>
  <td align=right x:num>4.39</td>
  <td align=right x:num>624</td>
  <td align=right x:num>390</td>
  <td align=right x:num>24</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.44</td>
  <td align=right x:num>3706</td>
  <td align=right x:num>649</td>
  <td align=right x:num>23</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.48</td>
  <td align=right x:num>3737</td>
  <td align=right x:num>6.2</td>
  <td align=right x:num>4.33</td>
  <td align=right x:num>660</td>
  <td align=right x:num>413</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.52</td>
  <td align=right x:num>3766</td>
  <td align=right x:num>667</td>
  <td align=right x:num>417</td>
  <td align=right x:num>0.9</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.56</td>
  <td align=right x:num>3820</td>
  <td align=right x:num>6.5</td>
  <td align=right x:num>20</td>
  <td align=right x:num>4.32</td>
  <td align=right x:num>689</td>
  <td align=right x:num>431</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.6</td>
  <td align=right x:num>3835</td>
  <td align=right x:num>6.6</td>
  <td align=right x:num>21</td>
  <td align=right x:num>688</td>
  <td align=right x:num>430</td>
  <td align=right x:num>0.91</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.64</td>
  <td align=right x:num>3854</td>
  <td align=right x:num>6.8</td>
  <td align=right x:num>4.34</td>
  <td align=right x:num>729</td>
  <td align=right x:num>456</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.68</td>
  <td align=right x:num>3905</td>
  <td align=right x:num>6.9</td>
  <td align=right x:num>22</td>
  <td align=right x:num>749</td>
  <td align=right x:num>468</td>
  <td align=right x:num>0.93</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.72</td>
  <td align=right x:num>3932</td>
  <td align=right x:num>777</td>
  <td align=right x:num>485</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.76</td>
  <td align=right x:num>3956</td>
  <td align=right x:num>7.1</td>
  <td align=right x:num>783</td>
  <td align=right x:num>490</td>
  <td align=right x:num>0.92</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.8</td>
  <td align=right x:num>4000</td>
  <td align=right x:num>7.3</td>
  <td align=right x:num>779</td>
  <td align=right x:num>487</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.84</td>
  <td align=right x:num>4014</td>
  <td align=right x:num>829</td>
  <td align=right x:num>518</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.88</td>
  <td align=right x:num>4030</td>
  <td align=right x:num>7.5</td>
  <td align=right x:num>832</td>
  <td align=right x:num>521</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.92</td>
  <td align=right x:num>4121</td>
  <td align=right x:num>7.6</td>
  <td align=right x:num>827</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>25.96</td>
  <td align=right x:num>4135</td>
  <td align=right x:num>876</td>
  <td align=right x:num>548</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26</td>
  <td align=right x:num>4124</td>
  <td align=right x:num>7.9</td>
  <td align=right x:num>4.35</td>
  <td align=right x:num>858</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.04</td>
  <td align=right x:num>4155</td>
  <td align=right x:num>919</td>
  <td align=right x:num>574</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.08</td>
  <td align=right x:num>4163</td>
  <td align=right x:num>8.2</td>
  <td align=right x:num>927</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.12</td>
  <td align=right x:num>4225</td>
  <td align=right x:num>8.5</td>
  <td align=right x:num>30</td>
  <td align=right x:num>934</td>
  <td align=right x:num>584</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.16</td>
  <td align=right x:num>4258</td>
  <td align=right x:num>961</td>
  <td align=right x:num>601</td>
  <td align=right x:num>0.94</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.2</td>
  <td align=right x:num>4299</td>
  <td align=right x:num>8.9</td>
  <td align=right x:num>32</td>
  <td align=right x:num>979</td>
  <td align=right x:num>613</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.24</td>
  <td align=right x:num>4382</td>
  <td align=right x:num>9.1</td>
  <td align=right x:num>33</td>
  <td align=right x:num>4.36</td>
  <td align=right x:num>992</td>
  <td align=right x:num>620</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.28</td>
  <td align=right x:num>4391</td>
  <td align=right x:num>1069</td>
  <td align=right x:num>669</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.32</td>
  <td align=right x:num>4421</td>
  <td align=right x:num>9.5</td>
  <td align=right x:num>35</td>
  <td align=right x:num>4.37</td>
  <td align=right x:num>1079</td>
  <td align=right x:num>675</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.36</td>
  <td align=right x:num>4466</td>
  <td align=right x:num>1103</td>
  <td align=right x:num>690</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.4</td>
  <td align=right x:num>4491</td>
  <td align=right x:num>10.1</td>
  <td align=right x:num>38</td>
  <td align=right x:num>4.38</td>
  <td align=right x:num>1107</td>
  <td align=right x:num>692</td>
  <td align=right x:num>0.95</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.44</td>
  <td align=right x:num>4534</td>
  <td align=right x:num>34</td>
  <td align=right x:num>1135</td>
  <td align=right x:num>710</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.48</td>
  <td align=right x:num>4571</td>
  <td align=right x:num>9.3</td>
  <td align=right x:num>1131</td>
  <td align=right x:num>707</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.52</td>
  <td align=right x:num>4586</td>
  <td align=right x:num>9.4</td>
  <td align=right x:num>36</td>
  <td align=right x:num>1163</td>
  <td align=right x:num>727</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.56</td>
  <td align=right x:num>4675</td>
  <td align=right x:num>9.6</td>
  <td align=right x:num>37</td>
  <td align=right x:num>1171</td>
  <td align=right x:num>733</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.6</td>
  <td align=right x:num>4647</td>
  <td align=right x:num>1182</td>
  <td align=right x:num>740</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.64</td>
  <td align=right x:num>4700</td>
  <td align=right x:num>9.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.68</td>
  <td align=right x:num>4711</td>
  <td align=right x:num>1137</td>
  <td align=right x:num>711</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.72</td>
  <td align=right x:num>4727</td>
  <td align=right x:num>1139</td>
  <td align=right x:num>713</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.76</td>
  <td align=right x:num>4838</td>
  <td align=right x:num>1154</td>
  <td align=right x:num>722</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.8</td>
  <td align=right x:num>4849</td>
  <td align=right x:num>1194</td>
  <td align=right x:num>747</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.84</td>
  <td align=right x:num>4860</td>
  <td align=right x:num>1178</td>
  <td align=right x:num>736</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.88</td>
  <td align=right x:num>4891</td>
  <td align=right x:num>1180</td>
  <td align=right x:num>738</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.92</td>
  <td align=right x:num>5016</td>
  <td align=right x:num>39</td>
  <td align=right x:num>1205</td>
  <td align=right x:num>754</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>26.96</td>
  <td align=right x:num>5060</td>
  <td align=right x:num>1219</td>
  <td align=right x:num>762</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27</td>
  <td align=right x:num>5041</td>
  <td align=right x:num>1207</td>
  <td align=right x:num>755</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.04</td>
  <td align=right x:num>4999</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.08</td>
  <td align=right x:num>5042</td>
  <td align=right x:num>1187</td>
  <td align=right x:num>743</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.12</td>
  <td align=right x:num>5065</td>
  <td align=right x:num>9.2</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.16</td>
  <td align=right x:num>5152</td>
  <td align=right x:num>1210</td>
  <td align=right x:num>757</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.2</td>
  <td align=right x:num>5217</td>
  <td align=right x:num>40</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.24</td>
  <td align=right x:num>5209</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.28</td>
  <td align=right x:num>5191</td>
  <td align=right x:num>1239</td>
  <td align=right x:num>775</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.32</td>
  <td align=right x:num>5293</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.36</td>
  <td align=right x:num>5275</td>
  <td align=right x:num>1226</td>
  <td align=right x:num>767</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.4</td>
  <td align=right x:num>5314</td>
  <td align=right x:num>1241</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.44</td>
  <td align=right x:num>5381</td>
  <td align=right x:num>41</td>
  <td align=right x:num>1251</td>
  <td align=right x:num>782</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.48</td>
  <td align=right x:num>5429</td>
  <td align=right x:num>1234</td>
  <td align=right x:num>772</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.52</td>
  <td align=right x:num>5424</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.56</td>
  <td align=right x:num>5489</td>
  <td align=right x:num>1246</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.6</td>
  <td align=right x:num>1282</td>
  <td align=right x:num>801</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.64</td>
  <td align=right x:num>5509</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.68</td>
  <td align=right x:num>5540</td>
  <td align=right x:num>1276</td>
  <td align=right x:num>798</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.72</td>
  <td align=right x:num>5546</td>
  <td align=right x:num>1269</td>
  <td align=right x:num>793</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.76</td>
  <td align=right x:num>5623</td>
  <td align=right x:num>42</td>
  <td align=right x:num>1284</td>
  <td align=right x:num>803</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.8</td>
  <td align=right x:num>5679</td>
  <td align=right x:num>1261</td>
  <td align=right x:num>788</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.84</td>
  <td align=right x:num>5686</td>
  <td align=right x:num>1266</td>
  <td align=right x:num>792</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.88</td>
  <td align=right x:num>5715</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.92</td>
  <td align=right x:num>5756</td>
  <td align=right x:num>1295</td>
  <td align=right x:num>810</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>27.96</td>
  <td align=right x:num>5745</td>
  <td align=right x:num>1314</td>
  <td align=right x:num>821</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28</td>
  <td align=right x:num>5798</td>
  <td align=right x:num>43</td>
  <td align=right x:num>1325</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.04</td>
  <td align=right x:num>5813</td>
  <td align=right x:num>4.44</td>
  <td align=right x:num>1303</td>
  <td align=right x:num>815</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.08</td>
  <td align=right x:num>5842</td>
  <td align=right x:num>1292</td>
  <td align=right x:num>809</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.12</td>
  <td align=right x:num>5851</td>
  <td align=right x:num>4.45</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.16</td>
  <td align=right x:num>5847</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.2</td>
  <td align=right x:num>5875</td>
  <td align=right x:num>44</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.24</td>
  <td align=right x:num>5919</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.28</td>
  <td align=right x:num>5947</td>
  <td align=right x:num>1297</td>
  <td align=right x:num>812</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.32</td>
  <td align=right x:num>5959</td>
  <td align=right x:num>8.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.36</td>
  <td align=right x:num>5991</td>
  <td align=right x:num>1306</td>
  <td align=right x:num>817</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.4</td>
  <td align=right x:num>6080</td>
  <td align=right x:num>45</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.44</td>
  <td align=right x:num>6098</td>
  <td align=right x:num>4.28</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.48</td>
  <td align=right x:num>6039</td>
  <td align=right x:num>8.7</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.52</td>
  <td align=right x:num>6168</td>
  <td align=right x:num>4.27</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.56</td>
  <td align=right x:num>6144</td>
  <td align=right x:num>1308</td>
  <td align=right x:num>818</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.6</td>
  <td align=right x:num>6195</td>
  <td align=right x:num>8.6</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.64</td>
  <td align=right x:num>6207</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.68</td>
  <td align=right x:num>6292</td>
  <td align=right x:num>1351</td>
  <td align=right x:num>845</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.72</td>
  <td align=right x:num>6263</td>
  <td align=right x:num>1328</td>
  <td align=right x:num>830</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.76</td>
  <td align=right x:num>6273</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.8</td>
  <td align=right x:num>1359</td>
  <td align=right x:num>850</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.84</td>
  <td align=right x:num>6356</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.88</td>
  <td align=right x:num>6352</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.92</td>
  <td align=right x:num>6372</td>
  <td align=right x:num>8.4</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>28.96</td>
  <td align=right x:num>6380</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29</td>
  <td align=right x:num>6488</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.04</td>
  <td align=right x:num>6428</td>
  <td align=right x:num>8.3</td>
  <td align=right x:num>1317</td>
  <td align=right x:num>824</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.08</td>
  <td align=right x:num>6450</td>
  <td align=right x:num>29</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.12</td>
  <td align=right x:num>6470</td>
  <td align=right x:num>4.31</td>
  <td align=right x:num>1333</td>
  <td align=right x:num>834</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.16</td>
  <td align=right x:num>6589</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.2</td>
  <td align=right x:num>6497</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.24</td>
  <td align=right x:num>6624</td>
  <td align=right x:num>8.1</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.28</td>
  <td align=right x:num>6683</td>
  <td align=right x:num>1300</td>
  <td align=right x:num>813</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.32</td>
  <td align=right x:num>6619</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.36</td>
  <td align=right x:num>6676</td>
  <td align=right x:num>1274</td>
  <td align=right x:num>796</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.4</td>
  <td align=right x:num>6570</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.44</td>
  <td align=right x:num>6738</td>
  <td align=right x:num>1289</td>
  <td align=right x:num>807</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.48</td>
  <td align=right x:num>6733</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.52</td>
  <td align=right x:num>6664</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.56</td>
  <td align=right x:num>6702</td>
  <td align=right x:num>1258</td>
  <td align=right x:num>787</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.6</td>
  <td align=right x:num>6690</td>
  <td align=right x:num>1236</td>
  <td align=right x:num>773</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.64</td>
  <td align=right x:num>6826</td>
  <td align=right x:num>1263</td>
  <td align=right x:num>790</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.68</td>
  <td align=right x:num>6711</td>
  <td align=right x:num>7.8</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.72</td>
  <td align=right x:num>6864</td>
  <td align=right x:num>1217</td>
  <td align=right x:num>761</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.76</td>
  <td align=right x:num>6782</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.8</td>
  <td align=right x:num>6869</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.84</td>
  <td align=right x:num>6902</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.88</td>
  <td align=right x:num>6841</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.92</td>
  <td align=right x:num>6950</td>
  <td align=right x:num>1243</td>
  <td align=right x:num>778</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>29.96</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30</td>
  <td align=right x:num>7.4</td>
  <td align=right x:num>4.68</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.04</td>
  <td align=right x:num>6894</td>
  <td align=right x:num>1201</td>
  <td align=right x:num>751</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.08</td>
  <td align=right x:num>6899</td>
  <td align=right x:num>4.63</td>
  <td align=right x:num>1222</td>
  <td align=right x:num>764</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.12</td>
  <td align=right x:num>6935</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.16</td>
  <td align=right x:num>6904</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.2</td>
  <td align=right x:num>7028</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.24</td>
  <td align=right x:num>7055</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.28</td>
  <td align=right x:num>6971</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.32</td>
  <td align=right x:num>7047</td>
  <td align=right x:num>7.2</td>
  <td align=right x:num>1215</td>
  <td align=right x:num>760</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.36</td>
  <td align=right x:num>7018</td>
  <td align=right x:num>1231</td>
  <td align=right x:num>770</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.4</td>
  <td align=right x:num>7049</td>
  <td align=right x:num>4.05</td>
  <td align=right x:num>1196</td>
  <td align=right x:num>748</td>
 </tr>
  <td height=17 align=right style='height:12.75pt' x:num>30.44</td>
  <td align=right x:num>7143</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
  <td width=126 style='width:95pt'></td>
  <td width=118 style='width:89pt'></td>
  <td width=102 style='width:77pt'></td>
  <td width=116 style='width:87pt'></td>
  <td width=128 style='width:96pt'></td>
 </tr>
 <![endif]>
</table>
You are supposed to adjust your fuel trims so they are at 0.
Also you want your timing to fall to about 9 when boost hits then steadily climb to around 19 at redline.
That turbo at low boost isn't going to make much power, 20psi+ is where it starts to shine.
can you explain about how i am supposed to adjust fuel trims to zero? can i safetly run 20psi on my engine?
ok after reading more and understanding what fuel trims are and looking into my ECU+ system more, it doesnt show LTFT or STFT. those reading i showed is pretty much it with the exception of stuff like coolant temp etc. based on that, how am i supposed to tune?
