Another injector question
Riceburning101
155
Jan 2, 2012
Fort Wayne, Indiana
Looking to upgrade injector size. I found a set of 1000cc PTE and a set of 850cc FICs. Price is the exact same shipped. The biggest turbo I am going to run is the HX40 or HX35 havent decided between the two but currently running the E3 16g. I dont plan on running E85 for awhile due to the availability of where i am currently at. So nothing bigger than HX35/40 turbo wise, boost level would be the highest knock will let me get to, and only running pump gas. Is it really worth going to the 1000cc's? I know the FICs are probably a better choice just due to the fact that they are flow tested within x%. What do you guys think?
Just get 1000cc injectors you got ecmlink run big. The only issue I had when running big injectors like 1450cc or 16500 on pump gas it ran ruff. But was good on e85.
With the 1000cc injectors and the HX35 you could still run E85 through them and not have to upgrade with a slight kick in fuel pressure. Give your car some room to stretch for future mods, there's nothing like upgrading injectors more than once and kicking yourself for not going bigger.
1000's no question.
:dsm:
I would go with the 1000cc set. Like the above stated, its never a bad idea to have room to grow. I remember when the biggest I would go was a hx40... you get the mod bug again sooner or later!
I agree with the 1k cc injectors. Although I believe you will be upgrading the 1k's once you go e85 because they are on the small side for e85. Good luck though :D
Partially true depending on how much horsepower your going to be making. That depends on how much injector you need.
