another idle issue thread
JuGs
674
Jul 20, 2008
Marshall, Wisconsin
Ok for the most part my car idles greeat and flawlessly. I have one issue with it on warm starts though. When I start the car after its been running it will not idle, unless i hold the rpms at around 1k to 2k rpms for roughly 15 seconds and then its fine and no issue untli i start it warm again. When its a cold start its fine only on warm or hot(at temp) starts.
I know its not the temp sensor I have replaced that already. My thermostat is also newer(6 months old)
My car is basicly stockish. 95 gsx with 6 bolt swap. Only mod right now is a greddy bov and 16g turbo. Im running stock injectors stock boost(9lbs) fuel pump n fpr also stock.
I want to get all my bugs fixed before I put in my fuel upgrades and turn up the boost. I know its not fast idle or idle surge because it idles to what i have it set to and doesnt jump around or anything. What am I over looking I only found a few threads simmular to this and all say temp sensor and to check for boost leaks. One i read had ruled out boost leaks because hot or cold it wouldnt matter.
I have no vaccume lines but for fpr and bov....ics was good when i took motor out of my 91. Bit i will try another one and see if it helps.
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
  • For sale 4G63 Powder Coated Valve Cover w/ 10an fittings & new baffles
    Powder Coated 4G63 Valve Cover w/ 10an fittings & new baffles $250 + shipping & paypal feesYou...
