GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
Seems like im starting to overpower my oem clutch with 3k miles on it. Ill drive slow through the winter and get ready for a clutch install this spring. I plan on getting: clutch, pressure plate, fork/ball, TOB (mitsu), and possibly flywheel (not aluminum)
I did a lot of reading and came across the act spring failure thread, has me scared of springs so I have a few questions that i would like cleared up.
BTW my car for now is essentially stock 92, AWD. I will eventually like to run a hx35 (maybe throw in a 16g until then...) once i get a lot more starting mods, but i probably wont see that turbo for a year or 2 while im building up for it... So maybe I should go with a lighter clutch for 2 years and switch in due time?
-SPRUNG/ UNSPRUNG?
Its doesnt seem like those springs do much, I dont care if dirveability is reduced slightly. I DO CARE IF ITS GOING TO RAPE MY TRANSMISSION! I dont care for clutches that spit out springs also. I know dumping the clutch = break sh!t, I wont be doing that. So for longetivity is it Sprung (easier on components) or Unsprung (no risk of failure from spitting springs)
-Pressure vs Friction:
Hypothetically which is better more frinction disc, with less pressure, or more pressure and less friction or more pressure, more friction? Am I correct of these trade offs? ie. More pressure = crank bearing wear, more friction = more surface wear? Whats a good compromise? Iguess im in the rang of 2100 and 2600...
-Long lasting materials?
I have narrowed a few options:
Clutches:
-SOUTHBEND TZ/FE seems like this will last the longest, drive smoothest, and hold power nicely.
-SBC Sprung kevlar (alternative to SB TZ/FE)
-ACT UNSPPRUNG street disc, or 6puck (dont want springs springing around... would this be too harsh on anything? ie, trans/driveline?)
Pressure Plates:
Cant go wrong in this area? seems like no one has anything bad to say, just get something with my desired pressure rating and call it a day? maybe do some brand matching? I want to stay as light as possible, like 2100 so I dont premature kill my thrust bearings, or should I not be worried (stock 6 bolt)?
End up going either act 2100/2600 or Southbend SS
Flywheel:
With only 25k on the factory flywheel, should I just resurface? I was also thinking of possibly going the ACT street light. general consensus seems to be dont go aluminum, especially for long/hard runs...
And at the marginal cost, I might as well do Fork, Pivot ball, TOB while im in there, anything else?
My ideal setup so far would be Southbend tz/fe, SS PP, and factory resurface Flywheel. I think this would give me the most reliability/performance for the cost.
My cheap setup would be ACT 2600 kit with UNSPRUNG street disc, anything wrong with that? TIA
-SPRUNG/ UNSPRUNG?
Clutches:
Pressure Plates:
Flywheel:
