ACT 6 Puck Sprung Center Clutch Disc
sharky559
191
Mar 6, 2010
Sanger, California
ok so im thinking of getting the New ACT 6 Puck Sprung Center Clutch Disc that dsm grave yard has. but can i use it with my stock pp since i dont plan on racing. i plan on daliy driving. any help would be good:confused:
You can use that disk under the stock pressure plate but I would got with at least a 2100 pressure plate if your no sticking with a solid disk. You might get some clutch slipping going on with less disk surface and not alot of pressure gripping against it.
just get the stg4 XTD wit spring kit its only like 190 out door and it works great.
just know if your not gana use it for racing just stick with a street disk style you wont like the quik pulls.
  • Wanted 6 bolt NT water pipe
    • chrisman287
