allrice4g63
- 176
- 0
- Jun 17, 2008
hager city,
Wisconsin
Hey guys running into a slight prob with my 95 awd... Got my car all tuned on 550s 14b at 18 psi. Drove it for a couple days and it pulled very very nicely with 18 degrees of timing with a 11.1 afr. Neways I did a launch just to test out my lsd front and rear and it was a eyeball sucking launch. Drove the car home parked it... Next day after work I fired it up for a cruise went to take off and rpms went shooting up like I was in nuetral. cluch is slipping and I cant gowitg th anywhere... So when it did drive it shifted like brand new and the clutch grabed flawlesly. So what happened here I checked and made sure the master and slave worked good and they do... I can push the slave in bye hand then when I move the clutch fork it moves up and down and side to side. Its really sloppy in the trans.. Did it fall off the pivot ball. Did my clutch explode... Dunno what the deal is.
