ItsStockOfficer
- 983
- 1
- Oct 25, 2002
Buenos Aires,
South America
Originally posted by MNGSX
Actually it looks ok... I just think there are better ways to do it.
Can you MIG and TIG weld?
I can![]()
Mild steel, Stainless, Aluminum... No problem.
I just don't understand why it is so damn hard for you to grasp that WG flow increases can make power.
It's a basic concept that decreasing restriction of exhaust flow creates gains. So If you increase flow tru the wastegate you can increase power.
It's like saying catbacks don't make power they just lower backpressure.
A wastegate that can flow more exhaust lowers backpressure between the turbine and the head better. Less backpressure = more power. A larger gate or a better flowing one can bypass more exhaust around the turbine. So if you are at full boost and you have alot more exhaust gas flow than what is needed to maintain that boost level you can run a lower exhaust manifold pressure.
How can a external wastegate flow more air out of it and run the same boost as an internal wastegate?
It can't.
If your running 20 PSI and you have to vent 20% of your air to do so, then you hafta vent that much air no matter whats doing it. If an external flowed more, it would RUN LESS BOOST.
10hp above the 3".
d pressure increase will create a boost pressure increase.
