am I going the right way on my build
Kod
289
Mar 29, 2011
Kingston, Pennsylvania
I have looked at the stage guides and this is my plans which will be a slow build.
3g. Lifters or high lifters
Big 16g Turbo
FMIC
Turbo back exhaust more than likely megan
550 CC Injectors denso with aem fuel rail and pressure regulator
Rewire fuel pump
Walsborro LP 255 spelling isn't correct
Automatic transmission
Ipt valve body
Alto end clutch
Replace filter
Clean all shift solenoids
The transmission work will be done all at once.
I'd lose the fuel rail and get bigger injectors, possibly 650's or 750's. Our fuel rail is massive to begin with and will flow plenty for your setup. The bigger injectors will be a safety net and will give u room to grow down the road.
Has routine maintainance been done? Timing belt, water pump, oil pump?
Its my DD just want it built for my own satisfaction and has some good power behind it.
Timing belt will be done soon as for water pump and oil pump what's best to do with that?_
