Am i F'd Log inside
D3monX
263
Jul 3, 2007
Fredericksburg, Virginia
is this bad? its version 2.5 by the way
im trying to find everything that i can do replace for the knock if you have any recommandations that would be great and yeah i have v3 software but didnt notice i was doing the log with 2.5 till i was done
So you want to replace the knock sensor? If so, you have to unthread it from the back of the block (might have to remove some stuff to get to it) and thread in the new one and torque to spec.
I'd recommend going and taking a new log or two (start off with an idle log and then maybe a short pull if you can keep it from knocking) and post it up. The new software is so much easier to help with as that's all I've been using since before it came out.
no i just replaced the knock sensor i will will go out with a slower pull/ partial throttle with an idle log, but does anything else look out of place besides the knock, like timing or airflow anything you can think of
Haha yeah i was in a rush to get a couple logs done and didn't notice when i had opened, but thank you for looking and i will post again when logs with V3 are up, thank you again
