alternator and p/s belt sizes please
Knome Twilight
Sep 15, 2005
Baltimore, Maryland
could someone please tell me the correct belt size for a 98 turbo? I can't find it anywhere, not even in my haynes or chiltons... please assist as I think the shop gave me the wrong belts but uncertain... Thanks!
~Keith
Poly-V, PS 4PK0700
4040365 Poly-V, AC 4PK0925
4040385 Poly-V, Alt & AT 4PK0980
4040390 Poly-V, Alt & MT 4PK0990
They can usually be off + or- 5mm depending on manufacturer
snowmon said:
Poly-V, PS 4PK0700
Thanks for getting back to me on this. I already worked it out but still appreciate it. I couldn't find the factory spec belts anywhere on the net and I was working on my car late so I couldn't call anywhere. The only reason I had to look it up is because ever since I've owned the car I keepe finding someone elses b/s backyard mechanics I was almost certain the belts on the car were not the correct size. When I got my new belts I matched them up and the were way to big. Come to find out the shop gave me the wrong sizes...
On a side note, have you ever seen an alternator spilt in two pieces? Thats how mine came out of the car when I replaced it this weekend. That and the p/s pump bearing was shattered. Whoever owned this before me was a complete hack...
Thanks again for the shout, at leat now there will be a record so when someone else needs the info... :)
~Keith
Still the same alternator/water pump belt part number for a '99 GSX 5spd with a JDM motor?
Been to the parts store 3x now getting the wrong size, from 35" to the latest 38.5in...would love to confirm that the belt I need is 4PK0990 which appears to translate to a 39.5in belt. Harmonic balancer destroyed the stock belt, can't use it to compare.
    • george bromwell
    • pma1123
    • Sdcryan1
