alternative clutch pedal setups?
dazzellerr
200
Dec 15, 2007
boise, Idaho
looking to upgrade the 1g clutch pedal assembly with something else. still keeping the hydraulic clutch setup even though i am used to a cable setup. i just do not have much room in my build under the column for the whole assembly (the talon has the up and over setup). i just want a basic pedal setup that goes straight through the firewall to the clutch master cylinder, ect.
anyone running something other than the talon pedal assembly on their car? i am not the best searcher, but i did search and read some threads with the key words i used, but nothing i found was very helpfull. i am planning on running the stock brake pedal with the master cylinder for the talon, but with another, different clutch setup not in one unit.
any advice or suggestions on this? i could make the talon one work, but i was thinking of a pedal assembly off a 90 mazda b2200 or similar.
thanks in advance people, you all have been very helpfull thus far in this project.
dazz
going to check summit and jegs right now...
yeah, i seen some on summit that were in the 500$ range. has the 3 pedals, floor mounted, with master cylinders included. also found a floor mounted clutch assembly for 50 bucks by itself. might be able to use the stock clutch master cyl with it if it has the right ratio (6:1.) hoping the talon pedal is 6:1 as well.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
