Alcohol Injection Kits
thilaksharma
310
12
Jul 3, 2006
Evo City, Asia
what are the comparison between the kit that you use and the others in the market, i did my survey and i lean towards the AEM kit , whats your opinion
Devils Own Kit vs AEM
Devils no longer have discount for dsmtuners as i have asked them , for $390 with 3bar map sensor with no float for level warning , i would say the advantage is on AEM as they have a built in map sensor , low level fluid warning and a aux output that can be tapped to ## ecu to reduce the timing incase fluid level drop, devilsownkit also do not give a tank to keep the fluid while the AEM kit gives a 1 gallon tank.
I checked out snowperformance , their kit doesnt come with low level fluid warning , it comes with a smaller tank but costs more
as for other kits , in my opinion, Cooling Mist has a cool software while Aquamist has the most advance software and pump.
what ## opinion on the AEM kit.
I don't about AEM but Snow Performance is top of the line, the stage 2 doesn't only rely on boost actuatation but has specially designed controller for each vehicle to ensure maximum power.
I love my Devilsown kit.. I got the base kit without progressive control and no
sensor..Got a 2qt tank and i gotta say i love it... simple and efective (very effective)
We are all around the same price. Got to remember aem does not come with a checkvalve, I still supprized they don't supply them with there kit. AEM even bought some thur us. But when it boils down to it most everyone is going to need one.
Our kit does not come with a tank, because most people use there factory washer tank. If you uses dsm link you can also use the map sensor with our kit to hook up to that too.
How much for one of these kits? I really dont want a fmic so im going to inject.
I used SMC Enterprise Injection kit with 100% meth for my EVO. $400~ish and lifetime warranty. If any seals go bad, pump goes bad.. the owner fixes it for free. When I do Meth for the DSM I'll go back to that kit :)
i dont like talking about products without using them but i had the same problem your having with what kit to buy. Everyone told me to stay away from AEM for some reason ( i do like AEM's products dont get me wrong... ) but i ended up going for the SnowPerformance. They do come with a small tank and no sender but i bought the sender from extreme psi already mounted in the tank. The kit is great and i would recomend it to anyone. All the parts went together well and the best thing is that part number 20009 is DSM specific. Snows tech is also very nice to deal with, and they answer any question without having to wait on hold. There may be a reason why AEM's kit comes with a 1 gal tank sender ect... and its so much cheeper. remember you get what you pay for.
oh and the 2qt tank lasts me a long time without filling it up. 3 days usually when i drive it normal
