iknowless
- 0
- Jun 21, 2010
Evans,
Colorado
Hey ya'll
So today I blocked the throttle open and pumped air into the #1 (TDC) spark plug hole with an air compressor and adapter @ about 20 psi. I can hear air coming out what seems like the intake side of the engine. I disconnected the fresh air intake hose, and I can definitely feel and hear air coming out.
What symptoms does this indicate? From what I know about compression checks, a little air will blow past the piston ring when they are not oiled and air will hiss out the oil cap, but at TDC all valves are closed, right?
I checked the rest of the cylinders at TDC, with the same result. Only I also noticed air coming out of the exhaust & the fresh air intake, and at the oil filler cap. When I close the throttle, less air comes out of the intake (to be expected?).
Looking forward to hearing some good reasons!
