Air/fuel and backfire issue after replacing timing belt tensioner
danielkile
47
Jun 11, 2010
York, Pennsylvania
After replacing my timing belt tensioner my car now backfires like crazy and the air/fuel pegs at 10 under boost car runs great when not in boost and idles fine. It's on a tune it ran fine on before.
Have performed a boost leak test? Is there any wiring you may have taken off that hasn't been plugged in or has a loose connection. Did you remove the timing belt when replacing the tensioner. Did you hold cams in place before removing belt? I would check it hasn't jumped a tooth.
+1 ^
It sounds like you might be off a tooth or two on either of your cams. How did you line up everything? Can you set the engine to TDV by the crank and take a picture of your cams for us?
Check over everything you touched to do timing. Double check timing marks are dead on with cyl 1 at tdc. Also go over any vac lines or couplers that you might have removed or loosened during your work.
