aftermarket toggle > factory fogs 1G
tim3kgt
34
Feb 5, 2003
LiberalProgrsv, Arizona
so i found a aftermarket, round toggle switch that fits into the factory location amazingly well. It has a little red LED in it to let me know when the Fogs are on. I prefer this to repairing the factory switch (again...). One problem: i need the wiring diagram or pin-out of the factory switch. It has four wires and the toggle needs 3. Ive read all of the VFAQ stuff and searched the forum and dsmtalk. can someone help me out please?
thanks
tim
This is just my thought. I may not be 100% correct but that's why we have other members to chime in :) The Rocker switch in reality only needs 2 but the 3rd prong is there for the led on the switch. There is 4 wires for the factory switch. Red w/ Black, Green w/ Red, Green w/ White and Black w/ Yellow. I have a harness in front of me and I am 90% sure the Black w/ Yellow is the ground. When I unraveled the tape from the harness there are 3 more Black w/ Yellow stripe and Red dots which lead to all of the other plugs except the dimmer and head light pop up, which leads me to believe the Black/Yellow is the ground. Next Find which wire has power when the PARKING LIGHTS are ON. Once this is established, Find which wire has power when the HEADLIGHTS are ON. When you find these 2 wires you should be able to combine the 2 wires 2 1 using a jumper or soldering them together into 1 wire. This new wire will be your hot. I believe that these 2 wires are the green wires. As for the red I don't know.
two are for illumination, the other two are for relay activation.
Illum. wire are not need
The power is green, the negative is red. odd, I know. should be on the far side of the connector.
Ignore the control relay text, text describing above parts in the actual schematic.
___________________________________________
How to wire it up
from top to bottom
ground wire - connected to a solid ground, under a screw, ect.
red wire
green wire
Hope that covered what you were after.
  • For sale 4G63 1G/2G parts
    2 pair of 91-94 shift cables, 91-94 shifter base, 2G auto parts
    • Jeff D
  • For sale 1g 1G Eprom ECU
    1G Eprom ECU $185 + shipping & paypal fees* great for someone with a 1G or GVR4 who wants to...
  • For sale 1g 1G Ortiz Center Vent Dual Gauge Pod ( discontinued )
    1G Ortiz Center Vent Gauge Pod $100 + shipping & paypal fees* long discontinued * gauges are...
  • For sale 1g 1GA Clear Corner Light Set
    1GA Clear Corner Light Set $65 + shipping & paypal fees* all mounting tabs are intactYou...
  • For sale 1g 1GA Talon Grill ( Great Condition )
    1GA Talon Grill $55 + shipping & paypal fees* Great Condition !You must be registered to see...
