afpr set up and vac source
josh1095
Banned Member
453
5
Aug 27, 2009
st. jacob, Illinois
do i set it without vac line attached while idling? also, im using the vac line originally coming off the stock fpr, is that ok? or should i tee into the line before the solenoid?
I used the stock vacuum line on my car, just so long as it is in good condition its fine. Also, yes, when the car is idling, disconnect the vacuum line and then set the base fuel pressure.
well, i adjusted it today after a nightmare with brand new pte 1000's leaking. dont want to get into that.
anyway, i set it to 43 w vac OFF and idling. plugged vac line back in and it dropped to around 37 i think. is this ok? and what should i use in link as my base fuel pressure? the higher or lower number?
nice, thanks sno. i think i may be on to why i was running a bit rich under WOT. more tuning after work tomorrow! i fn LOVE this endless black hole of cash LOL, seriously dsms are so fun to work on sometimes. just the learning is cool
