1g bov source with vac elimination
wranglerunner22
176
Jan 5, 2008
Chippewa Falls, Wisconsin
I saw a bunch of threads with some stuff but nothing with a straight answer.
Right now I have stock uicp and 1g bov. I have the vac elimination also. Where would the best source for the line that comes off the top of the bov? I cant seem to get it to open. But I took it off and tested it with a air compressor and it does indeed open with that pressure.
Any thoughts?
Any port right off of the intake manni will do.
You said it wont open. Do you have an aftermarket boost gauge to watch your boost level? What psi are you seeing thats max? Are you boosting past 10psi? Can you hear the BOV releasing pressure when boost has built andyou let off the throttle?
Actually, I don't think Im seeing any more then 10 psi. Even with a MBC.
Also, I have a N/T TB and IM.
From what I can tell I can indeed hear the BOV, it does have somewhat of a flutter to it tho.
