rubber vac hose for boost source
HTG
30
Oct 10, 2011
Winston-Salem, North Carolina
the rubber hose connecting my jpipe to my wastegate gets extremely hot. is it possible that once it gets hot, it closes and restricts boost flow/air flow causing my car to hesitate when boosting?
im considering every possibility!! thanks for any help!
yes super lean. and no, i dont smell gas and i have the missing link instead of a FCD
Detonation is probably your hesitation problem. Many people myself included use rubber line for vacuum hose with no problems.
You just started a thread a day or 2 ago asking about this. As you were already told, you are going to destroy the engine driving it without the fmu. STOP DRIVING IT. That is your problem, not some vacuum hose. You do not have an fmu, you don't have a boost gauge, you are asking for a blown engine. Do yourself a favor, do not even start the car until you have the fmu.
i am not driving it, havent for 2weeks..fmu on the way guys
If that hose gets hot and closes then that means you will over boost since there is no pressure to open the wastegate. Make sense?
