Vacuum hose for boost gauge needed
Devistator
Jun 17, 2004
Lincolnwood, Illinois
:dsm: I guess is 1/8 od clear vacuum hose.
Mine was bursting after 10-15 minutes of driving the car.
Cutting and cutting more to reconnect the hose left me without anny room to reconect the vacuum hose to the gauge. :barf:
I tried on the internet and all the auto stores with no success.
Please help me locate the place where i can order one.
Thanks
Go to the hardware store and get a fitting with a barb for the back of your boost gauge so you can use the black rubber hose. I don't think that clear stuff is that great.
The reason I don't like to use soft line is because it likes to flex and you don't get as accurate of a boost signal. If you want to do this, though, Home Depot sells brass fittings that will work for like $2-4, I think.
Coldandafraid said:
but it is tapped into the fuel pressure solenoid... which is already a "soft" line.
Agreed. My thought on this is there's only about two feet of soft line from the intake manifold to the FP solenoid and FPR, which isn't a whole lot of surface area to flex compared to 6+ total feet of of it going to the gauge. It's probably not enough to even make 1PSI gauge difference, but because I'm quirky like that, I know it'd bother me. :D
