boost source
Oh never mind i thout you had a n/a 4g63 well you just need to find a vaccum line and and tap into that it will work the same if you don't want to do that then just weld on a nipple on the turbo or IC pipe..
Tap into the compressor housing, or drill/tap/JBWeld a fitting into the compressor outlet elbow (J-pipe) that came in your turbo kit. Don't tap from the FPR line.
thanks guys
i think ama jus tap the ic piping a few inches away from the turbo compressor
what do you guys think?
To confuse everybody.
I don't really know, I think Chris fell asleep halfway through the promotion process. :)
