GRace
- 147
- 2
- Jan 25, 2011
Joplin,
Missouri
I have an aeromotive afpr. For some reason, I've been losing fuel pressure above 10 psi of boost. I'm leaning out. I've replaced the fuel filter and ran a straight fuel line from the pump to the fuel line in the tank to rule out an o-ring leak with the same results. My pump is rewired.
I guess my question is, how do I tell if I have the low pressure or high pressure spring in my afpr? Would I be able to even hold a base fuel pressure of 43.5 psi with the low pressure spring? I can crank the base fuel pressure up to 65 psi, I didn't go up any higher because I'm having problems below that fuel pressure...
