GBBALLIN
- 0
- Jul 3, 2016
Sioux Falls,
South Dakota
Just to start off I have been researching for almost a week on this issue with no results that helped I used forms and Google.
My car is a 98 eclipse gsx 7bolt
So I am having issues with my car it runs fine when it's cold, and I could boost it up to 25psi with no issues. But as soon as my car warns up to 200 °F it starts to stutter/sputter while cruising. I recently rebuilt my car with evo 8 pistons and replaced rod bearings and main bearings acl brand. Things I have already done replaced spark plugs re gapped the plugs down to .028, replaced plug wires, crank sensor was replaces as well, fuel pressure regulator, coolant temps sensor, and have done a boost leak test and have little to no leaks.
Car Build
Dsmlink, 255 walbaro fuel pump, 1250cc perscion injectors, running e85, unknown catback 2.5inch with gutted cat, dnp exhaust manifold, arp head studs, mls cometic head gasket with coper spray, head was milled down and have new seals and valves, evo 8 valve springs, fmi, arp main studs, acl thrust washers, balance shaft delete, ported oil filter housing, etc...
Car Build
