Ravenous
- 414
- 2
- Sep 20, 2003
West Linn,
Oregon
My car was getting low boost knock, 13-20 counts at around 5psi(14b mbc'd at 16psi). I believe the problem was that the base timing was off, that has been fixed. It was a little over 10 degrees advanced, not sure how that happened but it is fixed now. I am now reading 5 base with the terminal grounded and approx 7-8 at idle with ecu compensation. I also installed new FIC 850cc injectors, walboro 255hp fuel pump, and an Aeromotive fpr. Base fuel Pressure is approx 37psi with the vacuum line disconnected. I have compensated for the bigger injectors using tunerproRT and an ostrich romulator. They are set at 850cc compensation with 330us added to the deadtime across the board. The car now idles amazingly smooth and has a little growl to it, however when accelerating the car hesitates a bit. Boost is now maxing out at about 10psi. There is no knock at all, logger or on the knock gauge (boost gauge code altered on ostrich). To me it sounds like a boost leak, and I will test for that, but there is no smoke out the exhaust and nothing audible. Not to mention I didn't disconnect any intercooler hoses or remove any vacuum lines other than the fuel pressure line. Does anybody have any idea what this problem could be? It ran pretty good before even if the timing was way off? I will try to get some logs, I am using TMO but am going to try to get mmcd so I can log g/rev as well.
Any input positive or negative is greatly appreciated.
Thanks,
Chris
Thanks,
Chris
